Isobar Decay: 37Ar to 37Cl with Calculated Q Value (Neglecting Electrons)
  • Thread starter Thread starter coregis
The discussion centers on the decay modes between the isobars 37Ar and 37Cl, specifically focusing on the calculated Q value while neglecting electron contributions. The binding energies per nucleon are 8.279 MeV for 37Ar and 8.336 MeV for 37Cl. The calculated mass for 37Cl is 37.297009 u and for 37Ar is 37.295621 u, leading to a positive Q value of 1.292922 MeV, indicating that 37Cl decays to 37Ar via beta decay. However, it is noted that electron capture (EC) decay also occurs from 37Ar to 37Cl, suggesting a combined decay mode in practical scenarios.
  • Understanding of nuclear decay modes, specifically beta decay and electron capture.
  • Familiarity with binding energy calculations in nuclear physics.
  • Knowledge of mass-energy equivalence (1 u = 931.5 MeV).
  • Ability to perform mass calculations for nucleons (p=1.007277 u, n=1.008665 u).
  • Research the concept of binding energy and its role in nuclear stability.
  • Learn about the principles of electron capture (EC) decay in nuclear reactions.
  • Study the calculations for Q values in various nuclear decay processes.
  • Explore the implications of decay modes on nuclear reaction pathways and energy release.
Students and educators in nuclear physics, physicists analyzing decay processes, and researchers studying isobaric transitions and binding energy effects.
coregis
I think I am doing this correctly, but getting a strange result. Here's the original problem dealing with decay modes:
The isobars 37Ar and 37Cl have binding energies/nucleon of 8.279 Mev and 8.336 Mev, respectively. Show which nuclide decay to the other spontaneously and by what decay mode. (p=1.007277 u, n=1.008665u, 1u=931.5 Mev). Neglect contribution of electrons
Now, keep in mind that in reality, there is EC decay from 37Ar->37Cl.
First thing I did was to calculate Q for the reaction, which meant calculating the masses. I am neglecting electrons like the problem says and I think this is what is putting me off.
37Cl Mass=17*1.007277+20*1.008665=37.297009u
37Ar Mass=18*1.007277+19*1.008665=37.295621u
Oh no! Q must be positive, so now I have 37Cl->37Ar by beta decay...
Q=37Cl M - 37Ar M = .001988u * 931.5MeV/u=1.292922MeV
So did I do this wrong or does my professor want me to give him the fantasy world mode of decay? Am I supposed to use the energy/nucleon somehow? Help, I need all the points I can get. Thanks.
Ok, I figured it out. I need to take the binding energy and subtract it from the total mass of the separate nucleons to calculate the true mass to find Q. Hooray!
Your calculations and reasoning seem to be correct. The Q value for this reaction does come out to be positive, indicating that it is energetically favorable for 37Cl to decay into 37Ar by beta decay. However, as you mentioned, in reality there is also electron capture (EC) decay from 37Ar to 37Cl. This means that the actual decay mode would be a combination of beta decay and EC decay.
In terms of points, it would be best to clarify with your professor on whether they want you to consider only one decay mode or both. If they want you to consider both modes, then you can mention that the actual decay mode would be a combination of beta decay and EC decay. If they want you to consider only one decay mode, then beta decay would be the correct answer in this case.
9K
9K
