Solving the Ice Block Bullet Problem: Calculating Melting Quantity"
  • Thread starter Thread starter nemzy
The discussion centers on calculating the quantity of ice melted when a 3.9 g lead bullet at 31.8 °C is fired into a large block of ice at 0 °C. The key approach involves using the conservation of energy principle, where the energy lost by the bullet equals the energy gained by the ice. The specific heat of lead and the bullet's kinetic energy are critical components in determining the total energy change. Ultimately, the problem resolves by applying the latent heat of fusion for water to find the mass of ice melted.
  • Understanding of conservation of energy principles
  • Knowledge of specific heat capacity, particularly for lead
  • Familiarity with kinetic energy calculations
  • Concept of latent heat of fusion for water
  • Calculate the specific heat of lead using standard values
  • Learn how to apply the formula for kinetic energy in thermal problems
  • Research the latent heat of fusion for water and its implications in phase changes
  • Explore energy transfer calculations in thermodynamic systems
Students in physics or engineering, educators teaching thermodynamics, and anyone interested in practical applications of energy conservation in thermal systems.
nemzy
i am stuck on this problem:
a 3.9 g lead bullet at 31.8 C is fired at a speed of 279 m/s into a large block of ice at 0 C, in which it becomes embedded. what is the quantity of ice that melts??
well all i know is that i can find the specific heat and kinetic energy of the bullet, but where do i go from there?
So when the ice and the bullet come to thermal equilibrium their temperatures will be identical, let's call this temperature [tex]T^*[/tex]. Also, from conservation of energy we know that the energy lost by the bullet will be gained by the ice in the form of heat. Ok, so let's write the total energy change of the bullet.
[tex]\Delta E_{bullet} = -\frac{1}{2}mv^2 - Q_{transfer} = -\frac{1}{2}mv^2 - m c_{Pb} \ \Delta T[/tex]​
Here, [tex]c_{Pb}[/tex] is the specific heat of lead measured in units of Joules/kg C and [tex]\Delta T = T^* - T_{bullet}^{i} = T^* - 31.8^0 C[/tex]
Now here is where a trick comes in. Since the problem states that it is a "large block" of ice, we can assume that the temperature of the block of ice doesn't change. That is, the final temperature of both the bullet and block of ice is 0 C. Thus, [tex]T^* = 0 C[/tex].
From conservation of energy, [tex]\Delta E_{ice} = -\Delta E_{bullet}[/tex]. Now the problem is basically finished. You know how much energy was transferred from the bullet to the ice. To determine how much ice was melted (that is, went from solid water at 0 C to liquid water at 0 C), you must use water's latent heat of fusion.
why is kinetic energy negative, and why do u subtract the Qtransfer? shouldn't you add it to find the total energy change?
  • · Replies 17 ·
  • · Replies 28 ·
