Egg Safety Vehicle (Egg Drop Project in a car)
The discussion revolves around designing a protective vehicle for an egg as part of an egg drop project, where the vehicle will be rolled down a ramp and crash into other similar vehicles. Participants explore various design strategies and materials to ensure the egg's safety during impacts and falls, while adhering to specific project constraints.
  • Homework-related
  • One participant suggests using large wheels with weight around the outer rim to slow acceleration and extend impact time.
  • Another proposes a harness for the egg suspended with rubber bands to keep it away from the walls during falls, emphasizing the need for tightness in the bands.
  • A different viewpoint emphasizes the importance of energy absorption rather than storage, recommending a sliding seat mechanism to act as a shock absorber.
  • Concerns are raised about the visibility of the egg when using oatmeal as cushioning, leading to a proposal for a tunnel to maintain visibility while protecting the egg.
  • A participant later updates their strategy to a bubble wrap capsule suspended in cotton, indicating a shift in design approach.
Participants express various strategies and ideas for protecting the egg, but there is no consensus on the best approach. Multiple competing views on design features and materials remain throughout the discussion.
Participants are working within specific project constraints, including size and material limitations, which may influence their design choices. The effectiveness of proposed designs has not been empirically tested yet, and some ideas remain speculative.
Students or individuals involved in engineering projects, egg drop challenges, or those interested in design strategies for impact protection may find this discussion relevant.
triangle man
"Egg Safety Vehicle" (Egg Drop Project... in a car!)
Hey! This is my first post so sorry if I do anything against protocol.
I need to design a sort of egg protection vehicle. I will put the egg inside of the car which will in turn be rolled down a ramp and crash into one of my classmate's similar cars. So it's basically the egg drop project, but I will be "jousting" with my classmates.
There are only a few restrictions:
-- Body can be no larger than 6"x6" inclucing wheels (as for height... just not "crazy tall," whatever that means)
-- Body can not be more than half metal, wood, or plastic
-- Car must have a door that can open and close three times without breaking.
-- Car must have a "window" of 1"x1" (can be just a hole)
Oh and it can't consist solely of offensive features because there is an additional test: our teacher will (gently) kick our cars down one flight of stairs. I'm more worried about this test than the jousting.
I was thinking doing something with huge wheels to minimize the impact of my car as it tumbles down the stairs, and was planning to build a soft container for the egg that woule be suspended in oatmeal inside of a hard container.
Thanks!
Yeah why not make huge wheels with weight around the outer rim so your car accelerates slowly down the ramp?
Use the largest dimensions possible to extend the time of impact from every possible angle
probably seat your egg in the middle of the car
I'd suggest a harness inside for the egg suspended with rubber bands to the sides of the frame. Gotta make sure they are tight enough to keep it suspended away from the walls when falling down the stairs though. I've seen things kinda like this before for egg drops.
I'd say focus on offense and destroy the others cars before they have a chance to get kicked down the stairs
I'd think you would want something that absorbs the energy, not stores it like a rubber band. If you use a rubber band maybe find a way to create a sliding seat. Use rubber bands to hold it in a neutral position. Then you can use zip ties to make sure the seat will only slide one way. So kindof like a shock absorber if your rebound valve were jammed closed. It would only absorb the energy and not return it.
Of course rubber bands would be better than none because you are extending the time of impact.
Thanks for the pointers! Would the rubber band thing work if my "seat" was a bubble-wrap capsule suspended in oatmeal? I don't think the zip ties would work, as when it is kicked down the stairs, it will be absorbing force from every side and would be required to move in more than one direction to avoid breakage.
The only issue i have with that is that the egg has to be visible at all times, which is difficult to fulfill when it's buried in oatmeal. Would a tunnel from the surface of the box to the center (where the egg is) that does not contain oatmeal hurt the performance? So the egg's "seat" would be the tunnel. Does that make sense?
In case anyone reads this thread, I'm just going to say that I have changed my strategy to a bubble wrap capsule suspended in the middle of the carton and surrounded with cotton. I plan to put a paper cone on each side of the box except for the bottom. We test them Friday; I'll then report my results.
Sorry for the delay, but our teacher put off testing until today -__- We did a preliminary test thing 2 weeks ago, and mine was perfectly fine. Let's hope it works today...
  • · Replies 169 ·
17K
12K
