Java: Accessing Private Variables in Client Class
  • Context: Java
  • Thread starter Thread starter Bleys
    Java
The discussion revolves around the accessibility of private instance variables in a Java class when accessed from a client class. It examines whether a public method in a supplier class can modify a private variable when called from outside that class.
  • One participant questions whether calling a public method from a client class will change a private variable in the supplier class.
  • Another participant confirms that the private variable can be modified through the public method, emphasizing that direct access to the private variable is not possible.
  • A code example is provided to illustrate the scenario, showing the instantiation of the class and the method call.
Participants generally agree that the public method can modify the private variable, but the discussion does not explore any competing views or unresolved issues.
No limitations or unresolved issues are noted in the discussion.
Java programmers, especially those interested in object-oriented programming concepts related to access modifiers.
Bleys
Hello there; I have a very short question about client class access:
Suppose in a supplier class an instance variable is declared private (and is used in the constructor), and a void method in the same class (declared public) changes this variable. In the client class, is calling this method still going to change the variable (assuming an object of that class is instantiated of course). I know if the method is called within its own class then the variable will be changed, no problem. I was wondering whether the fact it's being called outside of its class makes a difference.
Something like:
public class Auto(){
private int gas;
public Auto(){
gas = 0
public void addGas(int g){
gas = gas + g;
and if addGas is called somewhere outside of the class, will the gas variable still be accessed and changed?
Technology news on Phys.org
Something like:
private int gas;
public Auto(){
gas = 0
gas = gas + g;
Yes, but it will not be accessed directly. Your public method addGas will do that.
Code:
Auto car = new Auto();
car.addGas(10);
The car instance is created with its gas property initialized to 0. The next line calls the addGas method to add 10 (gallons, liters?) of gas.
thank you, Mark!
  • · Replies 36 ·
  • · Replies 34 ·
  • · Replies 36 ·
  • · Replies 36 ·
