Calculating Impulse for a Truck Slowing Down: Momentum and Vector Help
  • Thread starter Thread starter butz3
    Momentum Vector
The discussion focuses on calculating the impulse experienced by a truck with a mass of 1.20 x 103 kg that decelerates from 24.0 m/s to 10.4 m/s over a period of 5.50 seconds. The impulse is determined using the formula F(Δt) = m(Δv), where Δv is the change in velocity. The impulse-momentum theorem confirms that impulse equals the change in momentum, allowing the calculation to be simplified by ignoring the time variable. The final impulse calculation results in a definitive value based on the mass and change in velocity.
  • Understanding of the impulse-momentum theorem
  • Familiarity with basic physics concepts such as mass and velocity
  • Knowledge of the formula for impulse: F(Δt) = m(Δv)
  • Ability to perform calculations involving scientific notation
  • Study the impulse-momentum theorem in detail
  • Learn how to calculate momentum and its implications in physics
  • Explore real-world applications of impulse in vehicle dynamics
  • Investigate the effects of varying mass and velocity on impulse calculations
Physics students, automotive engineers, and anyone interested in understanding the dynamics of vehicle braking and momentum changes.
butz3
i know that the formula for impulse is f(delta)t. my question ask " a truck with a mass of 1.20 x 10^3 kg has its brakes applied for 5.50s as it slows down from 24.0m/s, west to 10.4m/s west. determine the magnitude and direction of the impulse provided by the brakes." i know you need to use the formula
f(delta)t = m(delta)(vf-vi). but since i want the impulse do i just fill in the right side of the formula and git impulse or do i use the time also. thanks.
u can safely ignore "time=5.50s" as impulse is independent of time.
just impulse= (1.20 x 10^3)(24.0-10.4)
The impulse is the left-hand-side: (Favg)(Delta t).
By the impulse-momentum theorem, it then follows that it is equal to the change-in-momentum.
9K
  • · Replies 24 ·
