What is the coherence length and coherence time of the filtered light?
The coherence length and coherence time of filtered light can be calculated using the equations provided in the discussion. Given a mean wavelength of 600 nm and a pass band of 10 nm, the coherence length (lc) is determined using the formula lc = λ2/Δλ, resulting in a coherence length of 36,000 nm. The coherence time (τ0) is calculated using τ0 = 1/Δν, where Δν is derived from the spectral width, leading to a coherence time of approximately 0.6 ps.
  • Understanding of coherence length and coherence time in optics
  • Familiarity with the equations of wave optics
  • Knowledge of spectral width and its implications
  • Basic principles of monochromatic light and filters
  • Study the relationship between coherence length and wavelength in optical systems
  • Learn about the effects of spectral width on coherence time
  • Explore practical applications of coherence length in interferometry
  • Investigate the role of filters in manipulating light properties
Students and professionals in optics, physicists working with light coherence, and anyone involved in optical engineering or photonics research.
warfreak131
A filter is used to obtain approximately monochromatic light from a white sources. If the pass band of the filter is 10 nm, what is the coherence length and coherence time of the filtered light? The mean wavelength is 600 nm.
[tex]c\tau_{0}=l_{c}[/tex]
[tex]<\tau_{0}>=\frac{1}{\Delta\nu}[/tex]
[tex]l_{c}=\frac{c}{\Delta\nu}=\frac{\lambda^{2}}{\Delta\lambda}[/tex]
The problem gives me the wavelengths, so I would star by using the third equation. However, I don't understand the book's description of D lambda, the spectral width, and I'm not sure which wavelength to use, 600 nm or 10 nm,
That's not advanced physics. Still, I think that [tex]\lambda = 600 \tex{ nm}[/tex], and [tex]\Delta\lambda = 10 \tex{ nm}[/tex].
o, okay, thanks a lot
  • · Replies 66 ·
