Which direction does the Earth's permanent magnet point and why?
  • Thread starter Thread starter vsage
    Magnetism
The Earth's magnetic field behaves as if it is generated by a strong permanent magnet located in its core, aligned in a north-south direction. The north end of this magnetic field actually points toward the Earth's geographic North Pole, which is a common source of confusion. This phenomenon occurs because the magnetic north pole is situated near the Earth's geographic south pole. Understanding this relationship is crucial for interpreting magnetic navigation and geophysical studies.
  • Basic understanding of geomagnetism
  • Familiarity with Earth's magnetic field structure
  • Knowledge of magnetic pole definitions
  • Awareness of historical geomagnetic reversals
  • Research the concept of geomagnetic reversals and their implications
  • Study the Earth's magnetic field mapping techniques
  • Explore the use of compasses in navigation and their relation to magnetic poles
  • Investigate the effects of solar activity on Earth's magnetic field
Students in geophysics, educators teaching Earth science, and anyone interested in understanding the principles of Earth's magnetic field and its navigation implications.
vsage
This is a prelab question for a lab I'm supposed to do tomorrow but I feel like I'm so baffled at how simple the question is that I'm afraid to put down an answer for fear of misunderstanding the question:
The Earth's field appears as it were produced by a strong permanent magnet embedded in its core and aligned in the north-south direction. But which end is which? Which way do you think the north end of the Earth's permanent magnet points? Why?
From what I understand the north pole of Earth's magnetic field is only a few hundred miles away from the physical north and the south pole is only a few hundred miles away from the physical south. Which "way" the magnet points would be toward the physical south if I understand the correctly. As to "why" I can't even venture a guess because it's my understanding that the Earth has switched polarity plenty of times so I can't really give a definitive answer. Could someone offer a more clear explanation to this? I'd appreciate it.
Thanks for clearing that up. I knew the question had to be counterintuitive just by the fact that it was a lab question.
  • · Replies 40 ·
