What is the speed with which the water flows out of the hose
  • Context: Undergrad
  • Thread starter Thread starter jaidon
    Hose Speed Water
The discussion focuses on calculating the speed of water flowing out of a hose connected to a sealed tank under specific conditions. When the water height (h) is 3.50m, the absolute pressure of the compressed air is 4.20x10^5 Pa, and atmospheric pressure is 1.00x10^5 Pa. The flow speed can be determined using Bernoulli's principle and the equation for fluid dynamics. As the water level decreases to 3.00m and 2.00m, the flow speed changes accordingly, and the flow will stop when the water level reaches the height of the hose outlet.
  • Understanding of Bernoulli's principle
  • Knowledge of fluid dynamics equations
  • Familiarity with pressure calculations in fluids
  • Basic algebra for solving equations
  • Research Bernoulli's equation and its applications in fluid flow
  • Study the relationship between pressure and flow speed in fluids
  • Learn about the effects of atmospheric pressure on fluid dynamics
  • Explore the concept of hydrostatic pressure in fluid systems
Students studying physics, particularly those focusing on fluid mechanics, as well as educators and anyone interested in practical applications of fluid dynamics in real-world scenarios.
jaidon
I am new here so I hope that someone may have some advice. I am having trouble with a homework question which is quite lengthy. -- A large tank of water has a hose connected to it as shown in the figure. The tank is sealed at the top and has compressed air between the water surface and the top. When the water height, h, has the value 3.50m, the absolute pressure p of the compressed air is 4.20x10^5 Pa. Assume that the air above the water expands at a constant temperature, and take the atmospheric pressure to be 1.00x10^5 Pa. a)What is the speed with which the water flows out of the hose when h=3.50m? b)As water flows out of the tank, h decreases. Calculate the speed of flow for h=3.00m and h=2.00m c)At what value of h does the flow stop?-- The figure shows a tank of height=4.00m and the water level is lower than 4.00m giving the air gap. The hose is on the side in a "Z" shape with the top of the "Z" being 1.00m from ground level. I don't know if anyone can help, but I would appreciate the input.
1. There is no figure.
2. Since this is homework, it should be posted in the homework section.
(Though it was nice of you to tell us!)
  • · Replies 16 ·
9K
22K
  • · Replies 20 ·
12K
