At what value of h does the flow stop?
  • Thread starter Thread starter jaidon
    Flow Value
The discussion revolves around a physics problem involving fluid dynamics, specifically the flow of water from a tank through a hose under varying heights of water. The problem includes calculations related to pressure changes as the water level decreases and seeks to determine the conditions under which the flow ceases.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of pressure equations and the ideal gas law to relate the pressures at different water heights. There is an exploration of the implications of pressure changes on flow speed and the conditions for flow cessation.
The conversation includes attempts to derive relationships between pressures at different heights, with one participant expressing confusion over their calculations leading to unexpected results. Others have prompted the use of calculus and encouraged sharing of prior work to facilitate guidance.
Participants are working within the constraints of a homework assignment, which requires them to show their work and reasoning. There is an emphasis on understanding the physical principles involved rather than simply arriving at a solution.
jaidon
I am new here so I hope that someone may have some advice. I am having trouble with a homework question which is quite lengthy. -- A large tank of water has a hose connected to it as shown in the figure. The tank is sealed at the top and has compressed air between the water surface and the top. When the water height, h, has the value 3.50m, the absolute pressure p of the compressed air is 4.20x10^5 Pa. Assume that the air above the water expands at a constant temperature, and take the atmospheric pressure to be 1.00x10^5 Pa. a)What is the speed with which the water flows out of the hose when h=3.50m? b)As water flows out of the tank, h decreases. Calculate the speed of flow for h=3.00m and h=2.00m c)At what value of h does the flow stop?-- The figure shows a tank of height=4.00m and the water level is lower than 4.00m giving the air gap. The hose is on the side in a "Z" shape with the top of the "Z" being 1.00m from ground level. I don't know if anyone can help, but I would appreciate the input.
You will have to show us what you've done so far. (Read the sticky post at the top of the forum).
i believe that i figured out a) so for b) i was trying to determine the pressure at 3.00m. i used PV=nRT for 3.00m and PV=nRT for 3.50m and equated them. The nRTcancel and i get PV=PV. The tank is a cylinder so i said PAh=PAh. The A's cancel. P1h1=P2h2 with P1=4.20x10^5Pa, h1=3.50m, h2=3.00m solve for P2. I have done something wrong because this gives an increase in pressure when it should decrease. Anyone have some help for me?
Why not use your knowledge of calculus?
i think i just figured it out. thanks to anyone who considered the problem
10K
