Why Does a Voltmeter Show Negative Voltage?
The discussion centers on the concept of negative voltage as measured by a voltmeter. A voltmeter can display either positive or negative voltage readings depending on the reference point chosen in a circuit. The participants agree that while it is possible to avoid negative voltage by selecting an appropriate zero point potential, negative voltages serve practical purposes in circuit design. The analogy of measuring heights above sea level versus using a ground floor as a reference illustrates the utility of negative voltage in various applications.
  • Understanding of basic electrical concepts, including voltage and potential difference.
  • Familiarity with voltmeters and their operation.
  • Knowledge of circuit reference points and their significance.
  • Basic principles of electron flow and current direction.
  • Research the principles of circuit reference points and their impact on voltage measurements.
  • Explore the functionality and applications of digital multimeters in measuring negative voltages.
  • Study the implications of negative voltage in circuit design and analysis.
  • Learn about the relationship between gravitational potential and electrical potential in practical scenarios.
Electrical engineers, electronics students, and anyone interested in understanding voltage measurements and circuit design principles.
fisico30
Hello Forum,
maybe not a new topic but let me ask anyway.
The voltmeter is a simple device used to measure voltage or potential difference. Take a 9 Volt battery. If we connect it to a voltmeter the reading could be either +9 V or - 9 V. What makes one of the leads of voltmeter different from the other one such that the voltage reading can be negative? Current is actually electrons flowing from low to high potential
At times I am still confused about the concept of negative voltage. Given a circuit, we can choose any point and make it the reference point. That means that the voltage at that point can be called zero even if we don't connect that point with Earth ground, correct? Other points in the circuit can be at a positive or negative voltage. Is that all there is to say about negative voltage? We could get by without negative voltage by properly choosing the zero point potential. Why don't we do that?
thanks!
Yes.
How would we do that and what benefit would there be? I suppose a digital multimeter could be made to give an error message instead of a negative voltage reading, but that would just make it less useful.
If you were to build a house on top of a mountain, which would be better
1. Specify the heights of the floors and basement as heights above sea level.
2. Take the ground floor as zero and have positive heights to the upper stories and a negative height for the basement/
That is your question, re-stated in terms of gravitational potential rather than electric potential. Does that not show that Negative Voltages are useful?
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 19 ·
