Angle calculation from Atomic Term Symbol
The discussion focuses on calculating the smallest angle that the total angular momentum of an atom in a 7D term can make with the z-axis. The total angular momentum is defined by the quantum number J, with possible values derived from the equation 2S+1LJ. For the 7D term, S equals 3, leading to J values of 5, 4, 3, 2, and 1. The key to solving the angle calculation lies in maximizing the ratio of the projection of angular momentum along the z-axis (jz) to the total angular momentum (||j||).
  • Understanding of quantum numbers and angular momentum in quantum mechanics
  • Familiarity with the term symbol notation (e.g., 2S+1LJ)
  • Knowledge of vector projections in physics
  • Basic grasp of angular momentum operators in quantum mechanics
  • Study the derivation of angular momentum quantum numbers in quantum mechanics
  • Learn about vector projections and their applications in physics
  • Explore the implications of different term symbols on angular momentum
  • Review the principles of angular momentum measurement in quantum systems
Students studying quantum mechanics, particularly those preparing for exams involving angular momentum calculations, and educators seeking to clarify concepts related to atomic term symbols.
pdubbbs
Calculate the smallest angle (in degrees) that the total angular momentum of an atom in a 7D term can make with the z-axis.
2S+1LJ
Given that the total angular momentum of the atom is defined by the quantum number J, I started by finding all possible resultant J values for the term:
7D:
2(S)+1 = 7
S = 3
D = L = 2
J = { (L+S),(L+S-1), ... , (L-S) }
Thus, J = 5, 4, 3, 2, 1
This is where I'm stuck, I literally have no clue how to go further in the angle calculation. This is a review problem for an exam, and it was never covered in class. Hopefully someone can share some insight. Thanks for any help!
Your work is correct so far. When you measure the total angular momentum, what are the possible values? When you measure the projection of the angular momentum along the z axis, what are the possible values? You want the ratio of jz to ||j|| to be as high as possible, in order to minimize the angle that the total angular momentum makes with the z axis.
  • · Replies 0 ·
