Sodium street lamps and the light they emit
  • Context: Undergrad
  • Thread starter Thread starter AStaunton
    Light Sodium
This discussion focuses on the color perception of objects illuminated by sodium street lamps, specifically high-pressure and low-pressure sodium lamps. High-pressure sodium lamps emit a broader spectrum of light, allowing for some color differentiation, while low-pressure sodium lamps primarily emit a doublet of yellow light around 500nm, causing most colors to appear black. Users noted that while green hedges and silver cars retained some color visibility, other colors appeared dark or silhouette-like under low-pressure sodium lighting. The conversation highlights the limitations of color perception under different sodium lamp types.
  • Understanding of visible light spectrum and color theory
  • Knowledge of high-pressure and low-pressure sodium lamp technology
  • Familiarity with color perception and human vision
  • Basic principles of light absorption and reflection
  • Research the spectral output of high-pressure sodium lamps
  • Explore the effects of low-pressure sodium lighting on color perception
  • Investigate the principles of light absorption and reflection in different materials
  • Learn about alternative street lighting technologies and their color rendering capabilities
Individuals interested in lighting design, urban planners, and anyone studying the effects of artificial lighting on color perception.
AStaunton
when looking at objects illuminated by sodium street lamps, I felt that they appeared somewhat different from what expected from my (somewhat naive) understanding of light. My knowledge is (and I'm talking only about visible light) that if something is red, and white light is shone upon it, this object absorbs all light from the white light that isn't red and reflects the red light and so the object appears red and similarly for any other colour. so for example taking the red object again, if we now shine blue light upon it, the red object absorbs this light and as this time there is not red light to reflect it simply appears black or as a silhouette.
so going back to the sodium street lamp, when I looked object illumanited by it, I could still kind of make out their colour, for example the green of hedges I think I could make out and the browney colour of the bark of trees...looking at cars, mostly their colour was very hard to determine and they did appear quite dark maybe even silhouette like with the exception of silver cars, they still looked very silver.
As the visible lines of sodium is predominantly a doublet of yellow lines (I think of around 500nm but maybe I'm wrong) I would expect anything that is not a colour of this wavelength to appear as a silhoutte, but as I said above this was not the case.
Appreciate any comments or suggestions about this. Thanks
Science news on Phys.org
High pressure sodium lamps emit a bit of a wide enough spectrum to distinguish some colors. Low pressure sodium light makes yellow look orange and every other color look black for the reason you described.
  • · Replies 207 ·
16K
  • · Replies 24 ·
