New Reply
Hollow circular tube versus hollow rectangular shaft
Share Thread Thread Tools
Mar30-11, 12:17 PM   #1
Sportnut:
If I am using exact same aluminum material, with exact same thickness of gauge and I construct a 4ft long hollow circular tube that is 1" diameter, and I also construct a 4ft long hollow rectangular shaft that is 1" square, which would be more resistant to bending?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Mar30-11, 12:52 PM   #2
Recognitions:
Hard to say, but the circular pipe would resist bending equally in all directions. Whereas the square pipe would be great in horizontal and vertical directions but would quickly fail if you tried to bend it along a diagonal (making it diamond-shaped)
Mar30-11, 01:00 PM   #3
Thanks Bill. I appreciate your response.
Mar30-11, 05:36 PM   #4
Math 2012
Recognitions:
The square tube would be stiffer because more of the material is further from the centerline.
The stiffness ratio (from the second moments of area) is (1/12) / (pi/64) = about 1.7
Post #2 is wrong. The square tube is also equally stiff for bending in any direction, though this is not so "obvious" as it is for a circular tube.
New Reply
Thread Tools
Similar Threads for: Hollow circular tube versus hollow rectangular shaft
Thread Forum Replies
Calculate Mass Of Shaft and Hollow Shaft Mechanical Engineering 1
Replacing a hollow shaft with a solid shaft Engineering, Comp Sci, & Technology Homework 3
Torsion in hollow rectangular steel tube Mechanical Engineering 9
percentage saving in weight of sloid shaft Vs hollow shaft Engineering, Comp Sci, & Technology Homework 2
Percentage saving in weight of Hollow Shaft vs Solid Shaft Engineering, Comp Sci, & Technology Homework 24
