Calculate the probability that the electron is in the range
The discussion focuses on calculating the probability of finding an electron in the range (0, L/2) using the wave function defined as ψ(x,t) = (1/sqrt(2))[u2(x)e^(-iE2t/ħ) + u3(x)e^(-iE3t/ħ)]. The probability density function (PDF) is derived as |ψ(x,t)|^2 = |u2(x)|^2 + |u3(x)|^2 + 2Re[u2(x)u3*(x)e^(-i(E3-E2)t/ħ)]. The integration of this PDF over the specified range yields a time-dependent probability that oscillates based on the energy difference between states n=2 and n=3. The period of oscillation can be determined from the cosine term in the probability expression.
  • Understanding of quantum mechanics, specifically wave functions and probability density functions.
  • Familiarity with the infinite potential well model in quantum mechanics.
  • Knowledge of complex numbers and their manipulation in the context of quantum states.
  • Basic calculus skills for performing integrals over defined ranges.
  • Study the normalization of wave functions in quantum mechanics.
  • Learn about the properties of the infinite potential well and its energy states.
  • Explore the concept of time-dependent probability densities in quantum systems.
  • Investigate the implications of energy differences on oscillatory behavior in quantum mechanics.
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as educators looking to enhance their understanding of wave functions and probability calculations in quantum systems.
harpua
Was just wondering if anyone could help me w/ this question.
Consider the wave function
(psi (x,t)) = (1/sqrt(2))[u2(x)exp(-iE2t/h(bar) + u3(x)exp(-iE3t/h(bar)}. calculate the probability that the electron is in the range (0,L/2) as as function of time. What is the period of oscillation of the probability? NOTE: the wavefuctions u2(x) and u3(x) refer to the n=2 and n=3 states of the infinite well located at 0<x<L.
any help would be appreciated.
I'm guessing that [tex]u_3(x)[/tex] is supposed to have a coefficient of [tex]\frac{1}{\sqrt{2}}[/tex] (so that the wavefunction is normalised).
What you have to do is do calculate the probability integral for 0 < L < L/2. That is, do the integral from 0 < x < L/2 of [tex]\Psi^{*}\Psi[/tex]. You'll notice that the probability density [tex]\Psi^{*}\Psi[/tex] is no longer time-independent! It will wobble between being the u2 probability density and being the u3 probability density - figuring out the period of oscillation shouldn't be too hard once you have the density function sorted out.
Cheerio!
Kane
Sure, I'd be happy to help with this question. To calculate the probability that the electron is in the range (0,L/2), we can use the probability density function (PDF) given by:
|psi(x,t)|^2 = |u2(x)|^2 + |u3(x)|^2 + 2Re[u2(x)u3*(x)e^(-i(E3-E2)t/h(bar)]
where u2(x) and u3(x) are the wave functions for the n=2 and n=3 states of the infinite well, respectively. The term in the exponential represents the oscillation of the probability with time.
To find the probability in the range (0,L/2), we need to integrate the PDF over this range, which gives us:
P = integral from 0 to L/2 of |psi(x,t)|^2 dx
= integral from 0 to L/2 of [|u2(x)|^2 + |u3(x)|^2 + 2Re[u2(x)u3*(x)e^(-i(E3-E2)t/h(bar)]] dx
= integral from 0 to L/2 of |u2(x)|^2 dx + integral from 0 to L/2 of |u3(x)|^2 dx + integral from 0 to L/2 of 2Re[u2(x)u3*(x)e^(-i(E3-E2)t/h(bar)] dx
Since the wave functions for the n=2 and n=3 states are normalized, their integrals over the range (0,L/2) are equal to 1. This means that the first two terms in the above equation are equal to 1. The third term can be simplified using the identity:
2Re[u2(x)u3*(x)e^(-i(E3-E2)t/h(bar)] = |u2(x)||u3(x)|cos[(E3-E2)t/h(bar)]
Substituting this into the integral and using the fact that the wave functions are real (meaning their complex conjugates are equal to themselves), we get:
P = 1 + 1 + 2 cos[(E3-E2)t/h(bar)] integral from 0 to L/2 of |u2(x)||u3(x)| dx
The integral in the last term is just a constant, so it can be fact
  • · Replies 32 ·
  • · Replies 17 ·
