Angular momentum conservation.
The discussion centers around the effects of relativity on angular momentum conservation in a system of rotating masses. Participants explore the implications of relativistic effects on angular frequency and momentum when the radius of rotation is altered, comparing classical and relativistic frameworks.
  • One participant describes a classical scenario involving two point masses and questions how relativity would modify the conservation of angular momentum and energy when the radius is halved.
  • Another participant asserts that the concept of "center of mass" is not useful in relativity, suggesting the use of a "barycentric system" where total momentum is zero.
  • A different participant claims that angular momentum in special relativity retains the same form as in Newtonian mechanics, stating that if the radius is halved, the linear momentum must double to conserve angular momentum.
  • This same participant provides a formula relating momentum and velocity, indicating that the angular frequency remains defined as ω = v/r.
  • Further calculations are presented by another participant, showing how the doubling of linear momentum affects velocity, and confirming that their intuition about the relationship holds true regardless of mass value.
Participants express differing views on the applicability of the center of mass concept in relativity, with some advocating for the barycentric system while others maintain that angular momentum conservation principles remain consistent with classical mechanics. The discussion includes both agreement on certain mathematical relationships and ongoing uncertainty regarding the implications of relativity on the problem posed.
Participants note potential confusion arising from terminology, such as the use of "center of mass" versus "barycentric system." There is also mention of unresolved mathematical steps in the derivation of relationships between momentum, velocity, and angular frequency.
andrewr
I have been studying spin, angular momentum, etc. And became curious about how relativity would affect a classical problem: eg: that of a mass rotating around a center of mass;
In the classical case; two point masses of the same value, are separated by a distance 2r (mass-less attachement rod). This system has an angular frequency 'ω' which is in radians/second. The center of mass would be the midpoint r, and it can be considered at rest in our lab frame.
Now, classically, this is the kind of approach that can be taken with a figure skater, etc: If the momentum is conserved (energy too?), but the radius cut in half -- the velocity will exactly double to maintain conservation of momentum. (The angular frequency will quadruple.).
I intuitively know that increased velocity acts as increased mass under relativity. The rest mass is transformed/increased by a factor of motion. So, talking about a massive particle, I wanted to get an idea of how much the same problem would be affected in relativity. ( No crack ups about the figure skater ... it's hypothetical.)
I expect it isn't going to be a mass invariant problem; and so, I am thinking to define energy in a way that makes the actual mass irrelevant. EG: If I define energy to be in units of rest mass energy: eg: Tr=T/Em, so that when Tr=1 it means that for the amount of rest mass present, the kinetic energy is equal to the rest mass energy; so the total energy is 2 times the rest mass energy.
If I do this, and momentum is still conserved in the same problem -- but velocity corrected for relativity, I am thinking intuitively that the angular frequency will almost (but not quite) quadruple if the radius is cut in half; more mass=less velocity required for the same total energy.
Is this correct, and could someone estimate what halving the radius while keeping the total momentum constant would do to the angular frequency or velocity (or some other factor say 1/3, if that's more convenient than 1/2), I am not quite sure how to do it using the Lorentz transform, and when I looked around the web I came across mildly conflicting answers.
I didn't read your whole tract, but there is no useful concept of "center of mass" in relativity. What is useful is the "barycentric system", which means the total momentum is zero. In NR physics that corresponds to the center of mass system. One confusion is that almost all physicist call the barycentric system the "center of mass system", even though we know that is wrong. As with most colloquialisms, we know what we mean, but others may get confused.
It's actually pretty easy. Don't try to make it harder than it is by thinking in terms of rotating frames and so forth. Angular momentum in special relativity has the same value as it has in Newtonian mechanics, L = r x p. These are now 4-d quantities, but the value is the same and it's still conserved.
So the answer your question is, if r is halved and the angular momentum stays the same, then p must be doubled. What does this mean in terms of v?
p = γmv, solve for v and get
v = p/sqrt(m2 + p2/c2)
From this relationship, for a particular value of m you can work out what effect doubling p will have on v. The angular frequency? ω = v/r still holds.
OK. Bill.
If I take your approach and say the linear momentum is doubled, then I come up with:[tex] 2mv_{0}\gamma_{0}=\gamma mv=\frac{mv}{\sqrt{1-(\frac{v}{c})^{2}}}[/tex]
which solves to a v, of:
[tex]nv_{0}\frac{\sqrt{1-(\frac{v}{c})^{2}}}{\sqrt{1-(\frac{v_{0}}{c})^{2}}}=v\Longrightarrow n^{2}v_{0}^{2}\frac{1-\frac{v^{2}}{c^{2}}}{1-\frac{v_{0}^{2}}{c^{2}}}=v^{2}[/tex]
[tex]n^{2}v_{0}^{2}(c^{2}-v^{2})=v^{2}(c^{2}-v_{0}^{2})[/tex]
[tex]v=\left\{ \left(nv_{0}\right)^{-2}+\left(1-\frac{1}{n^{2}}\right)c^{-2}\right\} ^{-\frac{1}{2}}[/tex]
n=2, means 1/2 radius.
When I plug in small numbers it is almost exactly double, but not quite. So my intuition was correct.
This relationship happens to be true regardless of the value of mass.
That looks decent, did I miss anything?
  • · Replies 67 ·
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 82 ·
  • · Replies 38 ·
