How Does Kirchhoff's Loop Rule Apply to a Two Battery, Three Resistor Circuit?
  • Thread starter Thread starter helpme12345
The discussion revolves around applying Kirchhoff's Loop Rule to a circuit consisting of two batteries and three resistors. Participants are exploring how to determine the current in this circuit, noting that the junction rule may not be applicable in this context.
  • Some participants suggest combining the potential differences of the batteries and calculating the total resistance as a starting point. Others express confusion regarding the terminology used, particularly the phrase "magnitude of the direction of the current." There is also a mention of applying Ohm's law and the loop rule to analyze the circuit.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have provided guidance on how to start the problem, while others are questioning the clarity of the original poster's phrasing. There is no explicit consensus yet on the best approach to take.
Participants are operating under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. The original poster's phrasing has led to some confusion about the concepts being discussed.
helpme12345
I'm not sure where to begin. The problem asks to find the magnitude of the direction of the current in a two battery system with three resistors. However, it appears the junction rule cannot be applied. The loop rule may be implemented but I don't know how to get the current. The link to the problem is below.
http://negatrons.homestead.com/files/Kirchhoff.jpg
Add the two cell pd's together for a start - just because they aren't next to each other doesn't mean that you can't add them up (they are both connected the same way round.
Then find the total resistance and you are nearly there.
Also, post these in the homework help section in future!
Magnitude of the direction of the current? I didn't know direction had magnitude.
It's a simple series circuit. Combine the batteries and the resistors and apply Ohm's law.
[tex]\unitlength 2mm<br /> \begin{picture}(65,84.38)(0,0)<br /> \linethickness{0.3mm}<br /> \multiput(35,80)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(36.25,81.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(37.5,80)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(38.75,81.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(40,80)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(41.25,81.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \put(42.5,80){\line(1,0){1.25}}<br /> \put(37.5,82.5){\makebox(0,0)[bl]{R2}}<br /> \linethickness{0.3mm}<br /> \put(33.75,80){\line(1,0){1.25}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,73.75)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,73.75)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,71.25)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,71.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,68.75)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(58.75,68.75)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \put(60,66.25){\line(0,1){1.25}}<br /> \put(61.25,71.25){\makebox(0,0)[bl]{R3}}<br /> \linethickness{0.3mm}<br /> \put(60,75){\line(0,1){1.25}}<br /> \linethickness{0.3mm}<br /> \multiput(40,60)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(41.25,61.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(42.5,60)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(43.75,61.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(45,60)(0.21,0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \multiput(46.25,61.25)(0.21,-0.21){6}{\line(1,0){0.21}}<br /> \linethickness{0.3mm}<br /> \put(47.5,60){\line(1,0){1.25}}<br /> \put(42.5,62.5){\makebox(0,0)[bl]{R1}}<br /> \linethickness{0.3mm}<br /> \put(38.75,60){\line(1,0){1.25}}<br /> \linethickness{0.3mm}<br /> \put(55,78.12){\line(0,1){3.75}}<br /> \linethickness{0.3mm}<br /> \put(56.25,76.25){\line(0,1){7.5}}<br /> \put(52.5,84.38){\makebox(0,0)[bl]{V2}}<br /> \linethickness{0.3mm}<br /> \put(56.25,80){\line(1,0){3.75}}<br /> \linethickness{0.3mm}<br /> \put(51.25,80){\line(1,0){3.75}}<br /> \linethickness{0.3mm}<br /> \qbezier(30,70)(30,62.81)(30,61.25)<br /> \qbezier(30,61.25)(30,59.69)(30,60)<br /> \put(30,60){\line(1,0){10}}<br /> \qbezier(40,60)(40,60)(40,60)<br /> \qbezier(40,60)(40,60)(40,60)<br /> \linethickness{0.3mm}<br /> \put(28.13,73.75){\line(1,0){3.75}}<br /> \linethickness{0.3mm}<br /> \put(26.25,75){\line(1,0){7.5}}<br /> \put(23.75,76.25){\makebox(0,0)[bl]{V1}}<br /> \linethickness{0.3mm}<br /> \put(30,75){\line(0,1){3.75}}<br /> \linethickness{0.3mm}<br /> \put(30,70){\line(0,1){3.75}}<br /> \linethickness{0.3mm}<br /> \put(49,60){\line(1,0){11}}<br /> \linethickness{0.3mm}<br /> \put(60,60){\line(0,1){6}}<br /> \linethickness{0.3mm}<br /> \put(30,80){\line(1,0){5}}<br /> \linethickness{0.3mm}<br /> \qbezier(30,80)(30,80)(30,80)<br /> \qbezier(30,80)(30,80)(30,80)<br /> \linethickness{0.3mm}<br /> \put(30,75){\line(0,1){5}}<br /> \linethickness{0.3mm}<br /> \put(44,80){\line(1,0){7}}<br /> \linethickness{0.3mm}<br /> \put(60,75){\line(0,1){5}}<br /> \linethickness{0.25mm}<br /> \put(49,80){\circle*{1}}<br /> \linethickness{0.25mm}<br /> \put(30,80){\circle*{1}}<br /> \linethickness{0.25mm}<br /> \put(60,80){\circle*{1}}<br /> \linethickness{0.25mm}<br /> \put(60,60){\circle*{1}}<br /> \linethickness{0.25mm}<br /> \put(30,60){\circle*{1}}<br /> \put(62,82){\makebox(0,0)[cc]{C}}<br /> \put(65,72){\makebox(0,0)[cc]{}}<br /> \put(62,60){\makebox(0,0)[cc]{A}}<br /> \put(28,62){\makebox(0,0)[cc]{B}}<br /> \put(29,82){\makebox(0,0)[cc]{D}}<br /> \put(48,82){\makebox(0,0)[cc]{E}}<br /> \end{picture}[/tex]
While it may be really simple, let's apply the loop rule... to see that the rule really works [and so I can try to draw a circuit :cool: ].
(Assume that we traverse the loop clockwise, which defines our choice of "positive current" [akin to choosing an axis].)
[tex]\begin{align*}<br /> 0&=(V_B-V_A) + (V_D-V_B) + (V_E-V_D)+ (V_C-V_E)+ (V_A-V_E)\\<br /> &=(-I_1R_1)+(V_1)+(-I_2R_2)+(V_2)+(-I_3R_3)\\<br /> \intertext{in series, the currents are equal}<br /> &=(-IR_1)+(V_1)+(-IR_2)+(V_2)+(-IR_3)\\<br /> &=-I(R_1+R_2+R_3)+(V_1+V_2)\\<br /> \end{align*}[/tex]
Now, solve for the current [itex]I[/itex].
I think the original poster meant "magnitude and direction" of the current.
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 16 ·
