Is the Calorimeter Constant Calculation Correct?
The calorimeter constant calculation presented in the discussion is based on the heat transfer between cold and hot water. The heat lost by hot water is calculated as -4942.85 J, while the heat gained by cold water is 3619.88 J. The heat gained by the calorimeter is determined to be 1322.97 J, leading to a calorimeter constant of 76.38 J/°C. This calculation is confirmed as correct by participants in the discussion.
  • Understanding of specific heat capacity (4.18 J/g°C)
  • Basic knowledge of heat transfer principles
  • Familiarity with calorimetry concepts
  • Ability to perform algebraic calculations involving temperature changes
  • Review the principles of calorimetry and heat transfer
  • Learn about specific heat capacity calculations
  • Explore advanced calorimetry techniques and applications
  • Investigate common errors in calorimeter constant calculations
Students in physics or chemistry courses, educators teaching calorimetry, and anyone interested in thermodynamics and heat transfer calculations.
blicker
cold water: 50g
cold water temp: 22.23 C
hot water: 50 g
hot water temp: 63.2 C
final temp: 39.55 C
heat lost by hot water:
(4.18)(50)(39.55-63.22)=-4942.85
heat gained by cold water:
(4.18)(50)(39.55-22.23)=3619.88
heat gained by calorimeter:
-(-4942.85 J+3619.88 J)=1322.97 J
calorimeter constant:
1322.97/17.32=76.38
is this right? I am especially not sure about the last one.
Looks OK to me.
10K
