Expected value of function in binomial distribution
The discussion revolves around the expected value of a function in the context of a binomial distribution, specifically focusing on proving the equation E(1/(1+X)) = [1-(1-p)^(n+1)]/(p(n+1)), where X follows a binomial distribution Bi(n,p). Participants explore various steps in the proof and address potential errors in the calculations.
  • Homework-related
  • One participant outlines a series of steps attempting to prove the expected value, but expresses uncertainty about where they went wrong.
  • Another participant points out an error in adjusting the summation bounds when shifting from x to y.
  • There is a discussion about whether the summation still equates to 1 after the adjustment, with some participants questioning the validity of the steps taken.
  • One participant suggests that the original assignment question might be incorrect and proposes an alternative formulation of the expected value.
  • Another participant confirms the original question as stated and discusses the need to compensate for a first term in the summation.
  • Participants engage in clarifying the relationship between the summation and the total probability, emphasizing that the sum of probabilities for all outcomes should equal 1.
  • There is acknowledgment of a mistake regarding the lower bound of the summation, leading to a refined understanding of the components involved in the proof.
Participants do not reach a consensus on the correctness of the original assignment question or the steps taken in the proof. Multiple competing views remain regarding the proper formulation and the adjustments needed in the calculations.
Participants express uncertainty about specific mathematical steps and the implications of their adjustments. There are unresolved issues regarding the interpretation of the summation bounds and the compensation for terms in the expected value calculation.
kwy
Hi members,
Hope someone can help with this assignment question? I need to proof:
E(1/1+X) = [1-(1-p)^n+1]/p(n+1) where X ~ Bi(n,p)
Below are my steps and I'm not sure where I went wrong:
1. sum(x=0 to n) (1/1+x)*(n choose x)*p^x*(1-p)^n-x
2. sum(x=0 to n) (1/1+x)*[n!/x!*(n-x)!]*p^x*(1-p)^n-x
3. sum(x=0 to n) [n!/(x+1)!*(n-x)!]*p^x*(1-p)^n-x
4. sum(x=0 to n) [n!/(x+1)!*(n-x)!]*[(n+1)/(n+1)]*p^x*(p/p)*(1-p)^n-x
5. 1/p(n+1) * sum(x=0 to n) [(n+1)!/(x+1)!*(n-x)!]*p^x+1*(1-p)^n-x
let y = x+1
6. 1/p(n+1) * sum(y=0 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1
Think now the whole summation part equates to 1, leaving me with 1/p(n+1) only.
Any help will be much appreciated. Thanks in advance.
When you shifted from x to y you forgot to adjust the lower bound of the summation.
You need to compensate for the term you lost.
Thanks, but doesn't the summation still equates to 1?
6. 1/p(n+1) * sum(y=1 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1
Which would still leave me with 1/p(n+1) instead of [1-(1-p)^n+1]/p(n+1)?
The regular expectation of a binomial distribution with parameters n and p is given by:
EX = np
This means that:
sum(y=0 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1 = EY = (n+1)p
Apart from that we have a first term for which must be compensated.
This would be:
(1-p)^(n+1)
Can you put those together?
Oh dear, if EY is p(n+1), I think I somehow got the entire equation to equal to 1. I believe I went off the wrong track after line 3. Would you agree? Sorry, it's been close to 20 years since I've done this kind of maths. My brain just cannot interpret things as fast. I'm really appreciating your assistance. Thanks.
Now that I look at your assignment question again, I think the question is wrong.
I suspect it should be:
E(\frac 1 {1+X}) = 1- \frac {(1-p)^{n+1}} {p(n+1)} \text{ where } X \sim Bi(n,p)}
Can you confirm?
And as far as I can tell your calculation is entirely correct until step 6 where you added (1-p)n+1 without noticing.
Hi I like Serena
The question on the sheet definitely says
1 - (1-p)^n+1
p(n+1)
Cheers and thanks.
kwy said:
Hi I like Serena
1 - (1-p)^n+1
p(n+1)
Cheers and thanks.
My bad, the expectation EY is not in the picture.
You're quite right when you say:
sum(y=0 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1 = 1
This basically states that the sum of the chances on all possible outcomes is 1.
That still leaves the first term for which must be compensated.
More specifically:
1 = sum(y=0 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1 =
(1-p)^(n+1) + sum(y=1 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1
I got it. You are right about line 6 where the summation's lower bound should y=1. This means the summation part is:
which equates to say A - B where
A = sum(y=0 to n+1) [(n+1)!/y!*(n-y+1)!]*p^y*(1-p)^n-y+1 = 1
B where y is 0 giving [(n+1)!/0!*(n-0+1)!]*p^0*(1-p)^n-0+1 = (1-p)^n+1
Many thanks for the reminder.
Cheers
  • · Replies 0 ·
  • · Replies 29 ·
