| New Reply |
Trig right triangle solving question How do you know if you should pick tan40 degrees |
Share Thread | Thread Tools |
| Apr3-11, 07:34 PM | #1 |
Trig right triangle solving question How do you know if you should pick tan, cot, etc for the last part?
if b = 2 , A =40 , find a,c, and B I found all of them except for c , how do you get c There's a part almost at the end that goes like tan40 degrees = a/2 and Cos 40 degrees = 2/c Why do you know to pick Cos 40 , why not tan40 or cot of 40 for that last part there? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr3-11, 09:03 PM | #2 |
Recognitions:
What "last part there"? You haven't included whatever you're talking about in your post.
A guess about the use of cosine: To find an unknown with a trig function, you must have an equation that has the unknown in it along with other known information. If you want to find c and cosine involves c, use cosine. There is often more than one way to solve for an unknown. If c is the hypotenuse you can also use [tex] c^2 = a^2 + b^2 [/tex] to solve for it after you find b. |
| Apr4-11, 02:06 AM | #3 |
My guess is, although Stephen Tashi is right, it's usually best to only use values given in a question if you can, just in case your values calculated in other parts of the question are wrong, which could cause confusion if you get odd answers later on. |
| Apr4-11, 06:46 AM | #4 |
The convention is that, in a triangle, sides labeled a, b, c are opposite angles labeled A, B, C respectively.
And, in right triangles, by convention, C is the right angle and c is the hypotenuse. Back when you first learned about trig functions you were supposed to have learned something like: sine= opposite side/hypotenuse, cosine= near side/hypotenuse tangent = opposite side/near side Given angle A and side b, you think- a is the side opposite angle A and b is the other leg, the side "near" angle A so the appropriate formula is "tangent= opposite side/near side": tan(A)= a/b or tan(40)= a/2. Then solve for a. To find c, given only angle a and angle b, you think, c is the hypotenuse and b is the "near" side to A so the appropriate formula is "cosine= near side over hypotenuse": cos(A)= b/c or cos(40)= 2/c. Then solve for c. Of course, if, at this point, you have already solved for a, you could think "sine= opposite side over hypotenuse": sin(40)= a/c. Or, as Stephen Tashi said, you could use [math]c^2= a^2+ b^2[/math]. However, I agree with sjb-2812 that it is better to use the initially given values- you will not propagate arthmetic errors. |
| New Reply |
| Thread Tools | |
Similar Threads for: Trig right triangle solving question How do you know if you should pick tan40 degrees
| Triangle TRIG no Calculator | Precalculus Mathematics Homework | 1 | ||
| Right Triangles within a right triangle. (Trig) | Precalculus Mathematics Homework | 8 | ||
| Converting Inverse Trig Functions to Degrees | Precalculus Mathematics Homework | 9 | ||
| Trig Right Triangle Problem | Precalculus Mathematics Homework | 5 | ||
| Trig/Triangle problem. | General Math | 7 | ||
