DivGradCurl
- 364
Problem
Let [tex]\sum a_n[/tex] be a series with positive terms and let [tex]r_n = \frac{a_{n+1}}{a_n}[/tex]. Suppose that [tex]\lim _{n \to \infty} r_n = L < 1[/tex], so [tex]\Sum a_n[/tex] converges by the Ratio Test. As usual, we let [tex]R_n[/tex] be the remainder after [tex]n[/tex] terms, that is,
(a) If [tex]\left\{ r_n \right\}[/tex] is a decreasing sequence and [tex]r_{n+1} < 1[/tex], show by summing a geometric series, that
(b) If [tex]\left\{ r_n \right\}[/tex] is an increasing sequence, show that
My Solution
(a) The first term [tex]r_{n+1}[/tex] prevails, since it represents an upper bound to other terms of [tex]\left\{ r_n \right\}[/tex] . Then,
[tex]R_n \leq a_{n+1} + a_{n+1}r_{n+1} + a_{n+1}\left( r_{n+1} \right) ^2 + a_{n+1}\left( r_{n+1} \right) ^3 + \cdots = \sum _{n=1} ^{\infty} a_{n+1}\left( r_{n+1} \right) ^{n-1} = \frac{a_{n+1}}{1-r_{n+1}}[/tex]
(b) The last term [tex]L[/tex] prevails, since it represents an upper bound to other terms of [tex]\left\{ r_n \right\}[/tex] . Then,
[tex]R_n \leq a_{n+1} + a_{n+1}L + a_{n+1}L ^2 + a_{n+1} L ^3 + \cdots = \sum _{n=1} ^{\infty} a_{n+1}L ^{n-1} = \frac{a_{n+1}}{1-L}[/tex]
Questions
1. Did I get it right?
2. Why use "[tex]\leq[/tex]" instead of "[tex]<[/tex]", since all terms of [tex]\left\{ r_n \right\}[/tex] are smaller then their respective upper bounds?
3. Isn't an increasing [tex]\left\{ r_n \right\}[/tex] rather contra-intuitive when we consider a convergent series [tex]\sum a_n[/tex], which obeys: [tex]\lim _{n \to \infty} a_n =0[/tex]?
[tex]R_n = a_{n+1} + a_{n+2} + a_{n+3} + \cdots[/tex]
[tex]R_n \leq \frac{a_{n+1}}{1-r_{n+1}}[/tex]
[tex]R_n \leq \frac{a_{n+1}}{1-L}[/tex]
My Solution
Questions
That's it. Thank you very much!
