Integral on R^3: Change of Variable and Montecarlo Integration
  • Context: Graduate
  • Thread starter Thread starter zetafunction
    Change Variable
The discussion revolves around the use of spherical coordinates and Monte Carlo integration for evaluating improper integrals in R^3, particularly focusing on the transition from Cartesian to polar coordinates and the implications for convergence and divergence of integrals.
  • Some participants propose that a change of variable to spherical coordinates can be made even if the integral is divergent, suggesting that numerical methods could be used to integrate over angles, leading to one-dimensional integrals.
  • Others argue that a convergent integral should not become divergent under valid substitutions, questioning the feasibility of the proposed method.
  • One participant mentions that even divergent integrals can be analyzed using polar coordinates, particularly in the context of renormalization.
  • Another participant expresses skepticism, recalling that changes of variables in divergent integrals can lead to complications and suggesting that regularization should be applied first.
  • A later reply introduces the idea of using a regulator in polar coordinates to potentially make a divergent integral convergent, raising questions about the validity of this approach.
Participants express differing views on whether changing to spherical coordinates can help with divergent integrals. There is no consensus on the validity of the proposed methods, and the discussion remains unresolved regarding the effectiveness of these approaches.
Limitations include the dependence on the definitions of convergence and divergence, as well as the need for regularization in the context of quantum field theory, which some participants reference but do not fully elaborate on.
zetafunction
let be an integral on R^3 (imporper integral over all space)
[tex]\int_{-\infty}^{\infty}dx \int_{-\infty}^{\infty}dy \int_{-\infty}^{\infty}dz f(x,y,z)[/tex]
the integral is convergent , my question is if i can make a change of variable to spherical coordinates and then use MONTECARLO INTEGRATION to get rid of the angles so in the end we have an (approximate) sum of one dimensional integrals o the form
[tex]\int_{0}^{\infty} r^{2}drg(r)[/tex]
for some g(r)
for some g(r)
You didn't finish the question. Are you asking if this will work? There isn't anything wrong as far as I can see. g(r) must be independent of angle.
thanks mathmatn , i said that if you can always make a change of variable to polar coordinates (even the integral is divergent) and then use numerical methods to integrate over the angles to get a set (or sum) of 1-dimensional integrals
[tex]\int_{0}^{\infty}drg(r)r^{n-1}[/tex]
i used or try to discuss it with my physics teacher i order to obtain the renormalization for multi-loop integrals but they said it wouldn't work :( but gave no argument
for some g(r)
I don't know how a convergent integral can become divergent under any valid substitution.
i meant that we began with an initial DIVERGENT integral :S the question is that even for divergent integrals we can use polar coordinates
divergent integrals appear in RENORMALIZATION the idea is to reduce multiple integrals to 1-dimensional integrals by change to polar coordinates.
You can always change from Cartesian coordinates to spherical or vice versa. It won't effect convergence. If it appears that it does, there was an error.
Let me try to get this straight:
You have a divergent integral in Cartesian coordinates that is difficult to regularize. You want to know if it's possible that you can formally change to spherical coordinates and integrate out the angular variables without immediately getting an infinite result, leaving you with a radial integral that is still divergent but perhaps easier to regularize or otherwise deal with. Is this what you're hoping to do?
If so, I do not think this will work in general. I forget the details, but I remember learning in QFT that when you have a divergent integral, even a change of variables as innocent as [itex]x \rightarrow x + a[/itex] can be disastrous. You need to regularize the integral first, before you can make any changes of variables.
yes mute , is what you said
however if i introduce a regulator (in polar coordinates) so there will exist any big 's' with the regulator [tex](1+q_{a}q_{a})^{-s}[/tex] so that for big enough 's' the multiple integral will be convergent, is the method right ??
  • · Replies 29 ·
  • · Replies 16 ·
