New Reply
Wald: Ch. 2, Problem 8.b
Share Thread Thread Tools
Apr8-11, 01:14 PM   #1
Find the coefficients in coordinate bases, of the metric tensors for Minkowski space, for "rotating coordinates" defined by
[tex]t' = t,[/tex]
[tex]x' = (x^2+y^2)^{-1/2} \cos(\phi - \omega t),[/tex]
[tex]y' = (x^2+y^2)^{-1/2} \sin(\phi - \omega t),[/tex]
[tex]z' = z.[/tex]
I think the inverse coordinate transformation should be
[tex]t = t',[/tex]
[tex]x = (x'^2+y'^2)^{-1/2} \cos(-\phi + \omega t),[/tex]
[tex]y = (x^2+y^2)^{-1/2} \sin(-\phi + \omega t),[/tex]
[tex]z = z'.[/tex]
(EDIT: Insert prime symbols on x and y inside the brackets in the 3rd line of the inverse transformation.)
In Mathematica, I calculated the Jacobian matrix of this inverse transformation, using doubled letters for primed ones:
In[1]:= q = {tt, Sqrt[xx^2 + yy^2]*Cos[-phi + omega*tt],
Sqrt[xx^2 + yy^2]*Sin[-phi + omega*tt], zz}; J =
D[q, {{tt, xx, yy, zz}}]
Out[1]:= {{1, 0, 0, 0}, {omega Sqrt[xx^2 + yy^2] Sin[phi - omega tt], (
xx Cos[phi - omega tt])/Sqrt[xx^2 + yy^2], (yy Cos[phi - omega tt])/
Sqrt[xx^2 + yy^2],
0}, {omega Sqrt[xx^2 + yy^2] Cos[phi - omega tt], -((
xx Sin[phi - omega tt])/Sqrt[xx^2 + yy^2]), -((
yy Sin[phi - omega tt])/Sqrt[xx^2 + yy^2]), 0}, {0, 0, 0, 1}}
Then I calculated the new coefficients of the metric tensors thus:
In[2]:= g = DiagonalMatrix[{-1, 1, 1, 1}]; gg =
Transpose[J].g.J
Out[2]: {{-1 + omega^2 (xx^2 + yy^2) Cos[phi - omega tt]^2 +
omega^2 (xx^2 + yy^2) Sin[phi - omega tt]^2, 0, 0,
0}, {0, (xx^2 Cos[phi - omega tt]^2)/(xx^2 + yy^2) + (
xx^2 Sin[phi - omega tt]^2)/(xx^2 + yy^2), (
xx yy Cos[phi - omega tt]^2)/(xx^2 + yy^2) + (
xx yy Sin[phi - omega tt]^2)/(xx^2 + yy^2),
0}, {0, (xx yy Cos[phi - omega tt]^2)/(xx^2 + yy^2) + (
xx yy Sin[phi - omega tt]^2)/(xx^2 + yy^2), (
yy^2 Cos[phi - omega tt]^2)/(xx^2 + yy^2) + (
yy^2 Sin[phi - omega tt]^2)/(xx^2 + yy^2), 0}, {0, 0, 0, 1}}
The result is symmetric, but both the Jacobian matrix and the new coefficient matrix of the metric tensor field have determinant zero. I guess this means I'm doing something wrong, since the determinant of the latter matrix is used to measure spacetime volumes, but volume wouldn't be well defined if a particular volume could be zero when measured in one chart, and nonzero in another. Any suggestions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Apr8-11, 01:58 PM   #2
Recognitions:
Gold Membership Gold Member
It took me a moment to notice this issue, but there is something fishy about the transform. For given z and t, any x, y on the circle (x^2+Y^2)=k produce the same x', y' values. Thus, a circle in (x,y,z,t) gets mapped to a point in (x',y',z',t'). That's not a valid coordinate transform.
Apr8-11, 02:32 PM   #3
Ah, thanks, I see what's amiss now. I omitted his final condition: tan(phi) = y/x. Setting phi = ArcTan[y/x] gives a Jacobian matrix with determinant 1, and a metric matrix with determinant -1, as expected.
Apr8-11, 04:30 PM   #4
Recognitions:
Several typos in your transformation as given. (x2 + y2) should have an exponent + 1/2. Also in the sin, cos argument you want to change the sign of just t, not both φ and t. In other words, you want the (x,y) coords to rotate in the opposite (time-reversed) sense wrt (x',y'). Since cos is an even function and sin is odd, what you have written amounts to a reflection y' = - y.
Apr8-11, 06:06 PM   #5
Thanks, Bill. I never spotted the minus sign in the exponent in the LaTeX till you pointed it out; that was just a typo, and didn't enter my calculations. I did evenually realise my mistake with inserting a minus sign before the phi. Also, the argument of sine and cosine in the inverse transformation should be phi'+omega*t', where phi' = arctan(y'/x'), shouldn't it?
New Reply
Thread Tools
Similar Threads for: Wald: Ch. 2, Problem 8.b
Thread Forum Replies
Re: Wald's Isomorphism between V and V* General Physics 4
Re: Wald's Isomorphism between V and V* General Physics 0
Re: Wald's Isomorphisms Between V and V* General Physics 6
Wald's Isomorphism Between V and V* General Physics 6
R.Wald Science Textbook Discussion 2
