Understanding the Passive Sign Convention: Explaining P=+iv and P=-iv
The discussion revolves around the Passive Sign Convention in electrical circuits, specifically addressing the equations P=+iv and P=-iv. Participants explore the implications of these equations for passive elements like resistors, and the confusion surrounding the concept of power absorption versus power supply in these elements.
  • Some participants assert that P=+iv indicates that the element absorbs power when current enters through the positive terminal, while P=-iv indicates that it supplies power when current enters through the negative terminal.
  • Others argue that resistors can only dissipate power and cannot supply it, challenging the interpretation presented in an external article.
  • A participant questions how a resistor could be described as supplying power, emphasizing that from a physical standpoint, this is impossible.
  • Another participant suggests that the confusion may arise from using "resistor" generically for any two-terminal element, implying that the terminology may lead to misunderstandings.
  • Some participants clarify that while resistors dissipate energy, other passive elements like capacitors and inductors can store and release energy.
  • There is a discussion about the negative sign for power when current enters from the negative terminal of a resistor, with some participants asserting that current does not actually enter through the negative terminal.
Participants generally disagree on the interpretation of resistors in the context of power supply versus power dissipation. There is no consensus on the explanation of the negative sign for power in relation to current entering through the negative terminal.
Participants express uncertainty regarding the definitions and implications of power in relation to passive elements, particularly resistors. The discussion highlights the need for clarity in terminology and the potential for misinterpretation of power equations.
Charismaztex
From what I understand: P=+iv (current enters through the positive polarity of the voltage, implying that the element is absorbing power) and P=-iv (current enters through the negative polarity of the voltage, implying that the element is releasing or supplying power)
I remember reading that there are passive elements (resistors etc. which dissipate energy) and active elements (batteries etc. which supply energy). I recall that resistors only dissipate energy but the wiki entry here:
http://en.wikiversity.org/wiki/Passive_sign_convention
example 1.2 suggests that the resistor is supplying energy. How can this be explained?
Dude screwed up.
One thing could be is that he's erroneously using "resistor" for any two terminal element, if someone stuffed in "element" I think one would be okay
This is wrong example. A resistor can only dissipate power and it can't never supply power.
The writer of the article wrote "Find PTotal and Determine if this resistor is supplying power or dissipating it." How can a resistor be supplying power? I know from a physical point of view it is impossible for resistors to supply power but how do we explain the negative sign for power if the current enters from the negative terminal of a resistor?
as perfection pointed out, he tried to use a resistor as a generalized passive linear circuit element. resistors cannot store and release energy, of course, but other elements that are passive can. for electrical circuits, those passive elements are capacitors and inductors.
The fact is current never enters the negative terminal of a resistor (in the sense you mentioned) and the power will never be negative.
Ah, thanks. I think that's the key. I saw a diagram in my textbook with the current going
i--->+[resistor A]- i---> -[resistor B]+ and I thought that the current passes through the negative terminal of resistor B first. But the actual voltage across resistor B is negative, indicating that the "+" side of resistor B is -V voltages above "-" side, hence "-" side has a higher potential than "+" side. Thus current goes from higher potential to lower potential through the resistor.
  • · Replies 20 ·
