Question dealing with the conservation of mechanical energy.
The problem involves a skateboarder moving along a ramp and transitioning into projectile motion. The discussion centers on the conservation of mechanical energy to determine the maximum height reached after leaving the ramp, with specific attention to kinetic and potential energy transformations.
  • Participants explore the relationship between initial and final velocities using conservation of energy principles. Questions arise regarding the calculation of launch velocity and the impact of velocity orientation on kinetic energy.
Participants have engaged in clarifying the algebra involved in energy conservation equations and have provided feedback on calculations. There is a focus on breaking down velocities into components for further analysis, with some guidance on avoiding rounding errors in intermediate steps.
Some participants express uncertainty about the correct launch velocity and the implications of energy conservation in the context of the ramp's angle and height. The discussion reflects a learning process with varying interpretations of the problem setup.
scroobnab
The drawing shows a skateboarder moving at 5.4 m/s along a horizontal section of a track that is slanted upward by 48° above the horizontal at its end, which is 0.40 m above the ground. When she leaves the track, she follows the characteristic path of projectile motion. Ignoring friction and air resistance, find the maximum height H to which she rises above the end of the track.
I felt like my attempt was going well, but i can't seem to get the right answer. So i started out by realizing that Ef=Eo (i think), so KEf+PEf=KEo+PEo. I am just confused as to how i should go about calculating thee final speed, which i think i need to be able to complete the equations for H.
also, sorry i don't have the picture attached, I am new to the site and not even sure how to do that..
Can you put a number to the launch velocity (the skateboarder's speed as she leaves the end of the ramp)?
Thats one of my main questions... would that value be 5.4/cos48? so 8.07 m/s?
So with that in mind, when dealing with a problem involving KE, does the orientation of the velocity matter?
The orientation will become important in the next step. First you need to be able to find the correct launch velocity. This is determined by the kinetic energy that the skateboarder has when she reaches the top of the ramp. She begins on the horizontal with a given velocity, then rises up the ramp. While she goes up, she will be trading some kinetic energy for potential energy (due to gravity). Can you write a conservation of energy expression for this process?
so would the velocity at the end be:
1/2(m)(Vo)^2 + mgho = 1/2(m)(Vf)^2 + mghf
cancelling the m's, and isolating for Vf:
Vf = (2 (1/2(Vo)^2 - ghf))^1/2
if so, i calculated vf (at the end of the ramp) to be 5.02 m/s
You've got the right idea, but I think your algebra may have a bit of a problem.
1/2(m)(Vo)2 + mgho = 1/2(m)(Vf)2 + mghf
Cancel the m's and multiply through by 2, and take ho = 0,
vo2 = vf2 + 2ghf
vf2 = vo2 - 2ghf
vf = sqrt(vo2 - 2ghf)
Plugging in your given values:
vf = 4.617 m/s (Keep an extra decimal place for intermediate results)
Oh okay, yeah stupid mistake. Alright now I'm getting a value of 4.6 m/s. So now I'm supposed to move on to the next section of her jump using this as the initial velocity?
Right. Make a habit of hanging onto an extra decimal place or two for intermediate results in order to avoid rounding errors biting you in the end. Round results (answers) to the required precision.
So, the skateboarder leaves the ramp at the velocity that you've calculated, at the angle given for the ramp. This velocity can be broken into horizontal and vertical components, which can be treated independently. If you calculate the vertical component of the velocity, you should be able to use the appropriate equation of motion to determine the maximum height that she will reach.
okay bear with me here lol. so with that value i can use kinematics to solve for the rest right?
Vo = 4.617 m/s
ay = -9.8 m/s
Vf = 0 m/s
then solve for y?
Vo = 4.617 m/s
ay = -9.8 m/s
Vf = 0 m/s
then solve for y?
Yes, that's the idea. Keep in mind that the Vo value is the composite speed; you need to break it down into its horizontal and vertical components, and use the vertical component to determine the maximum height.
Alright, i did this and got a value of 3.43 for Voy. after plugging the values into the equation my value for y was 0.6 m.
Thank you SO much for your help, this has been really helpful and has cleared up a lot of questions i had about Kinetic Energy and such. Cheers!
13K
