Balancing Redox Reactions using half reactions?
  • Thread starter Thread starter kshah93
    Reactions Redox
The discussion focuses on balancing redox reactions using half-reactions, specifically the reaction involving chlorine species in an acidic medium. Participants explore the correct formulation of half-reactions and the identification of the oxidizing agent.
  • Homework-related
  • One participant presents an attempt to balance the redox reaction by separating it into two half-reactions, expressing uncertainty about the next steps after formulating them.
  • Another participant suggests using a standard reduction potential table to find a specific half-reaction involving Cl2 and H2O, but does not clarify its relevance to the original problem.
  • A third participant reiterates the previous suggestion about the half-reactions, prompting a question about the inclusion of HClO in the first half-reaction.
  • A participant questions the necessity of HClO in the half-reaction, noting that the conditions are acidic and HClO is a weak acid.
  • There is a concern raised about the answer key not including HClO, which leads to further questioning of the proposed half-reaction formulations.
Participants express differing views on the correct formulation of half-reactions and the presence of HClO, indicating a lack of consensus on how to balance the redox reaction accurately.
Participants reference standard reduction potentials and the conditions of the reaction (acidic), but there are unresolved questions about the appropriateness of certain species in the half-reactions and the overall balancing process.
kshah93
Use half reactions to balance the following redox reactions and underline the oxidizing agent.
a) Cl2 + ClO3{-} -> ClO{-} (acidic)
{} is the charge
e{-} is electrons
Not applicable
Well I tried to separate and write the two half reactions:
1) Cl2 + 2e{-} -> 2Cl{-} (I took this directly from my standard reduction potentials table)
2) ClO3{-} -> ClO{-} (I attempted to balance this half-reaction as it didn't appear on my table)
4H{+} + ClO3{-} + 4e{-} -> ClO{-} + 2H2O (I added 2H2O to the right side to balance the oxygen and then added 4H{+} on the left side to balance the hydrogen, then added 4 electrons (4e{-}) to the left side to balance the charges)
Once determining both half reactions, I am stuck, and am not sure exactly how to proceed.
The answer key to this question states:
2Cl2 + ClO{3-} + 2H2O -> 5ClO{-} + 4H{+} with ClO{3-} as the oxidizing agent.
Did I approach this question incorrectly and how am I supposed to balance this redox equation using half reactions?
This might help.
Using standard reduction potential table from Wikipedia, you could find this half:
Cl2 + 2H2O <------> 2e + 2H+ + 2HClO
and other half, based on your telling from message:
4H+ + ClO3- +4e <--------> ClO- + 2H2O
symbolipoint said:
This might help.
Okay, thanks for responding. I have one question. For your first half reaction, why is there an HClO?
You stated that the conditions are acidic solution. HClO is a weak acid.
Yeah, but the answer key doesn't have an HClO in it at all.
  • · Replies 18 ·
