Solving Geometric Progression & Logarithmic Equations Math Questions
The discussion revolves around solving mathematical problems related to geometric progressions and logarithmic equations. The original poster presents three specific questions involving properties of geometric series and logarithmic identities.
  • Mixed
  • Participants are exploring the properties of geometric progressions, particularly the relationship between the sum to infinity and the first term. There is also discussion on solving logarithmic equations using properties of logarithms. Some participants question the correctness of the original problem statement regarding the common ratio.
Several participants have prompted the original poster to share their attempts at solving the problems, emphasizing the forum's guideline against providing direct answers. There is ongoing exploration of logarithmic properties and their application to the equations presented.
Participants are noting potential issues with the problem setup, particularly regarding the convergence of the geometric series and the assumptions about the common ratio. There is also a mention of the starting index for the series in the third question, indicating a need for clarification on how to approach it.
I'm clever
I'm stuck on these three maths questions.
1) In a geometric progression, the sum to infinity is four times the first term.
(i) Show that the common ratio is 3
(ii) Given that the third term is 9, find the first term.
(iii) Find the sum of the first twenty terms.
2) Solve the equation log_2 x + 2 log_2 3 = log_2(x + 5).
3) Find:
200
Σ (3n+2)
n=101
for 3) Should I subtract the series cause it doesn't start with 1?
Show us what you have tried. (We can't just give answers here.) For #2 you'll need to use the logarithmic property
[tex]\log_b xy = \log_b x + \log_b y[/tex]
... among others.
... among others.
[tex]\log_2 x + 2\log_2 3 = \log_2 (x+5)[/tex]
Power rule:
[tex]\log_2 x + \log_2 3^2 = \log_2 (x+5)[/tex]
Addition rule:
[tex]\log_2 (x \times 3x^2) = \log_2 (x+5)[/tex]
[tex]\log_2 3x^2 = \log_2 (x+5)[/tex]
Power rule:
Addition rule:
Is this right?
Power rule:
Addition rule:
Where did that second "x" come from? It should be
[tex]\log_2 (x \times 3^2) = \log_2 (x+5)[/tex]
or
[tex]\log_2 (9x) = \log_2 (x+5)[/tex]
After this, use the property:
if logb x = logb y, then x = y
... and solve for x.
Are you sure you copied the problem right? My understanding is that unless r < 1 the series won't converge. If the sum to infinity is four times the first term, then I'm getting 3/4 as the common ratio, not 3.
