Is there a transistor that acts like a relay?
  • Thread starter Thread starter JerryG
    Relay Transistor
The discussion centers on the need for a four-pin transistor that isolates both positive and ground connections, specifically seeking alternatives to common drain or common source configurations. The recommended solution is to utilize solid state relays, which typically employ an optocoupler in conjunction with a triac. The mention of silicon-controlled rectifiers (SCRs) suggests a focus on devices that can handle similar functions in isolation applications.
  • Understanding of solid state relays and their components
  • Familiarity with optocouplers and their applications
  • Knowledge of triacs and their operational principles
  • Basic electronics concepts, including transistor configurations
  • Research the specifications and applications of solid state relays
  • Learn about the operation and use cases of optocouplers
  • Explore the characteristics and applications of triacs
  • Investigate silicon-controlled rectifiers (SCRs) and their functionalities
Electronics engineers, hobbyists designing isolation circuits, and anyone interested in solid state relay technology.
JerryG
I need some kind of four pin transistor that is neither common drain nor common source. Both positives and grounds need to isolated. Does that exist?
They are called solid state relays. Usually an optocoupler in conjunction with a triac.
  • · Replies 48 ·
15K
