How Do Forces and Friction Affect Block Acceleration?
The discussion revolves around a physics problem involving two blocks sliding across a table under the influence of an applied force and friction. The original poster seeks assistance with calculating forces and accelerations related to the blocks.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants suggest identifying forces acting on each block and applying Newton's laws. There are attempts to set up equations based on known forces and accelerations, with some participants expressing confusion about the setup for specific parts of the problem.
Guidance has been offered regarding the identification of forces and the setup of equations. Participants are exploring different aspects of the problem, including the direction of forces and the correct application of Newton's laws. There is no explicit consensus, but productive discussion is ongoing.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on understanding the relationships between forces, friction, and acceleration.
Naeem
Q. Two blocks are sliding across a table pushed by a force F from the left equal to 23 N. The force of friction from the table on m1 is 4 N and the force of friction on m2 is 12 N. m1 = 2 kg and m2 = 6 kg.
a) What is the magnitude acceleration of the entire system?
I figured this part out. Turns out to be 0.88 m/s2
But need help with the following parts.
b) What is the magnitude of force from m1 on m2?
c) What is the magnitude of acceleration of only m1?
d) What is the magnitude of force from m2 on m1?
Thanks,
Naeem
Start by identifying (labeling) the forces on each block. Then apply Newton's laws to one of the blocks and see what you can deduce.
I found out that the acc, for part c is 0.88 m/s2, but please help me with setting up
part b and d.
Thanks,
Start by doing what I suggested in my last post. Pick a block (m1, say) and identify all the forces on it.
I tried setting up but no use.
all I know is F= ma
and
Ffric - Fapp = m * a
found combined acc. for part a which is correct.
Please help me in setting up eqns,
Thanks,
You need to solve for the vector force.
all I know is F= ma
and
On m1 there are three forces acting (horizontally):
(1) the applied force: 23 N to the right
(2) the friction from the table: 4 N to the left
(3) the force that m2 exerts on m1: that's what you need to find out! (which direction does it act?)
Now set up your equation.
May be something like this:
F21 + F fric - Fapp = max
F21 + 4 - 23 =6 ( 0.88 )
Almost. But direction, and thus the signs, matters. (Also, you have the wrong mass.) I'll take positive to mean "to the right", thus:
[tex]F_{app} - F_f - F_{21} = m_1 a[/tex]
and so:
[tex]23 - 4 - F_{21} = (2)(0.875)[/tex]
Thanks, very much Doc, for all you guiding and help
  • · Replies 17 ·
