QFT Dirac Chiral Equations of Motion
The discussion focuses on deriving the equations of motion for the left-handed and right-handed components of the Dirac field, defined as \(\psi_L(x) = \frac{1}{2}(1-\gamma_5)\psi(x)\) and \(\psi_R(x) = \frac{1}{2}(1+\gamma_5)\psi(x)\). The Lagrangian density is given by \(L(x) = \mathrm{i} \hbar c \overline{\psi}_L(x) \gamma^\mu \partial_\mu \psi_L(x)\), which describes zero-mass fermions with negative helicity and zero-mass antifermions with positive helicity. The user expresses confusion regarding the decoupling of these components in the limit of zero mass and seeks clarification on their approach to the problem.
  • Understanding of Dirac equations and spinor fields
  • Familiarity with the properties of gamma matrices and the Dirac Lagrangian
  • Knowledge of helicity and its significance in particle physics
  • Ability to manipulate Lagrangian densities and derive equations of motion
  • Study the derivation of the Dirac equation from the Lagrangian density
  • Learn about the implications of chirality in quantum field theory
  • Research the role of helicity operators in particle physics
  • Examine the decoupling of fields in the context of massless limits
Students and researchers in theoretical physics, particularly those focusing on quantum field theory, particle physics, and the mathematical formulation of fermionic fields.
orentago
From Mandl and Shaw (exercise 4.5):
Deduce the equations of motion for the fields:
[tex]\psi_L(x)\equiv{1 \over 2} (1-\gamma_5)\psi(x)[/tex]
[tex]\psi_R(x)\equiv{1 \over 2} (1+\gamma_5)\psi(x)[/tex]
for non-vanishing mass, and show that they decouple in the limit m=0. Hence show that the Lagrangian density
[tex]L(x)=\mathrm{i} \hbar c \overline{\psi}_L(x) \gamma^\mu \partial_\mu \psi_L(x)[/tex]
describes zero-mass fermions with negative helicity only, and zero-mass antifermions with positive helicity only.
Lagrangian density for Dirac field:
[tex]L=c\overline{\psi}\left[ \mathrm{i}\hbar\gamma^\mu \partial_\mu -mc\right] \psi(x)[/tex]
Equations of motion:
[tex]{\partial L \over \partial \psi} - {\partial \over \partial x^\mu} \left(\partial L \over \partial \psi_{,\mu} \right)=0[/tex]
I'm not exactly sure where to begin, partly because I don't understand the wording of the question. Do I simply swap [tex]\psi[/tex] for [tex]\psi_L[/tex] and [tex]\psi_R[/tex] into the Lagrangian above and sub this into the equations of motion as per normal, or should I swap [tex]\psi(x)[/tex] for [tex]\psi_L(x)+\psi_R(x)[/tex]?
For the second part I'll have to use the helicity operator I expect, but I'll cross that bridge when i come to it.
I'm still stuck on this. I tried to go for the former of the two approaches mentioned above. I let [tex]\psi\rightarrow\psi_L[/tex] and [tex]\overline{\psi}\rightarrow\overline{\psi}_L[/tex], then:
[tex]L=c\overline{\psi}_L\left(\mathrm{i}\hbar\gamma^\mu\partial_\mu-mc\right)\psi_L[/tex]
Splitting this into two terms and tackling individually:
[tex]c\overline{\psi}_L\mathrm{i}\hbar\gamma^\mu\partial_\mu\psi_L=c\left(1-\gamma_5\right)\overline{\psi}\mathrm{i}\hbar\gamma^\mu\partial_\mu\left(1-\gamma_5\right)\psi[/tex]
[tex]c\overline{\psi}_L mc\psi_L=c\left(1-\gamma_5\right)\overline{\psi} mc \left(1-\gamma_5\right)\psi[/tex]
Then I expand the brackets and use the anticommutation relations [tex]\left[\gamma_5,\gamma^\mu\right]_{+}=0[/tex] and [tex]\left[\overline{\psi},\gamma^\mu\right]_{+}=0[/tex] to get:
[tex]c\left(1-\gamma_5\right)\overline{\psi}\mathrm{i}\hbar\gamma^\mu\partial_\mu\left(1-\gamma_5\right)\psi={1 \over 2}\mathrm{i}\hbar c \left(1-\gamma_5\right)\overline{\psi}\gamma^\mu\partial_\mu \psi[/tex]
and
[tex]c\left(1-\gamma_5\right)\overline{\psi} mc \left(1-\gamma_5\right)\psi=0[/tex]
So
[tex]L={1 \over 2}\mathrm{i}\hbar c \left(1-\gamma_5\right)\overline{\psi}\gamma^\mu\partial_\mu \psi[/tex]
Substituting this into the equations of motion and doing some rearrangement gives:
[tex]{1 \over 2} \mathrm{i}\hbar c\left(1-\gamma_5\right)\gamma^\mu \partial_\mu\overline{\psi}=0[/tex]
A similar process for [tex]\psi_R[/tex] gives:
[tex]L={1 \over 2}\mathrm{i}\hbar c \left(1+\gamma_5\right)\overline{\psi}\gamma^\mu\partial_\mu \psi[/tex]
with equations of motion:
[tex]{1 \over 2} \mathrm{i}\hbar c\left(1+\gamma_5\right)\gamma^\mu \partial_\mu\overline{\psi}=0[/tex]
This leaves me a bit confused. I'm pretty sure I've gone wrong somewhere, as the two equations don't decouple in the zero-mass limit. Can anyone see where I've gone wrong?
EDIT: In fact I'm fairly sure they're not coupled at all!
Does anyone have any hints for this, or should I have another stab and post my findings?
  • · Replies 0 ·
