How Is Path Length Difference Calculated in a Two-Slit Interference Pattern?
The path length difference in a two-slit interference pattern is calculated using the formula ΔL = d sin(θ), where d = 0.115 mm is the slit separation and θ is the angle from the beam axis. For the first maximum (m=1), the path length difference equals the wavelength λ = 595 nm, leading to the equation d sin(θ) = λ. Using the small angle approximation, the angle θ for the first maximum can be determined, providing a clear understanding of the interference pattern formed on the screen located 2.43 m away.
  • Understanding of wave interference principles
  • Familiarity with the small angle approximation
  • Knowledge of basic trigonometry
  • Concept of monochromatic light sources
  • Calculate the angle θ for the first maximum using the derived formula
  • Explore the effects of varying slit separation on interference patterns
  • Investigate the role of wavelength in determining interference maxima
  • Learn about the applications of two-slit interference in modern physics
Students studying wave optics, physics educators, and anyone interested in understanding the principles of interference patterns in light waves.
msusparty1136
Two slits separated by a distance of d = 0.115 mm are located at a distance of D = 2.43 m from a screen. The screen is oriented parallel to the plane of the slits. The slits are illuminated by a monochromatic and coherent light source with a wavelength of λ = 595 nm. A wave from each slit propagates to the screen. The interference pattern shows a peak at the center of the screen (m=0) and then alternating minima and maxima. What is the path length difference between the waves at the first maximum (m=1) on the screen? At what angle from the beam axis will the first (m=1) maximum appear? (You can safely use the small angle approximation.)
Assume the rays from the slits are effectively parralell. A maximum occurs when the path length difference is a multiple of the wavelength because this is constructive interference. The path length difference is dsin(theta) which for constructive interference is equal to m(lamda).
