Can Operators Be Divided in the Schrodinger Equation Derivation?
The discussion focuses on the derivation of the Schrödinger equation, specifically addressing the manipulation of operators within the equation. The equation is represented as iħ dU(t)/dt = HU(t), where H is the Hamiltonian and U is the time evolution operator. The user questions the validity of dividing operators and rearranging them, particularly in the context of matrix representations. The solution provided involves using an integrating factor, leading to the conclusion that U(t) = e^{-iHt/ħ} is valid under the assumption that H is time-independent.
  • Understanding of the Schrödinger equation and its components
  • Familiarity with Hamiltonian mechanics
  • Knowledge of operator algebra in quantum mechanics
  • Basic concepts of matrix operations and inverses
  • Study the derivation of the time evolution operator in quantum mechanics
  • Learn about the role of the Hamiltonian in quantum systems
  • Explore operator algebra and its applications in quantum mechanics
  • Investigate the use of integrating factors in solving differential equations
Students of quantum mechanics, physicists, and mathematicians interested in operator theory and the foundations of quantum equations.
skateboarding
I had a math question about the following steps.
The Shroedinger's equation can be written as follows.
[tex]\LARGE i\hbar \frac{d}{dt}U(t) |\psi(0)> = HU(t)|\psi(0)>[/tex]
Where H is the hamiltonian and U is the time evolution operator.
So U satisfies the Schrödinger equation.
[tex]\LARGE i\hbar\frac{d}{dt}U(t) = HU(t)[/tex]
This is the part that I don't quite understand.
If the hamiltonian H is independent of time, the solution to the above equation is
[tex]\LARGE U(t) = e^{-iHt/\hbar}[/tex]
This is a solution of integration with respect to U to solve for the differential equation.
My problem is that i can't seem to justify the expression:
[tex]\LARGE \int i\hbar \frac{dU(t)}{U(t)} = \int Hdt[/tex]
Am I allowed to divide operators and shuffle them around? Furthermore, when I think of operators in their matrix representation, I am even more confused, since I do not know of matrix division, only inverse operations on matrix.
Any help would be appreciated. Thanks.
If you're not happy with separating variables you can always use an integrating factor:
[tex] \LARGE \frac{d}{dt}\left(U(t)e^{iHt/{\hbar}}\right) = 0[/tex]
So then:
[tex] \LARGE U(t)e^{iHt/{\hbar}} = U(0)[/tex]
U(0) can be normalised to 1 therefore [tex] \LARGE U(t) = e^{-iHt/\hbar} [/tex]
