What Is the Required Magnetic Field for a Proton to Pass Through Undeflected?
The required magnetic field for a proton to pass through undeflected in the presence of a uniform electric field of 390 V/m is determined by balancing the electric and magnetic forces acting on the proton. Given the proton's mass of 1.67 x 10^-27 kg and charge of +1.6 x 10^-19 C, the magnetic field must be oriented perpendicular to both the velocity of the proton and the electric field. The magnitude of the magnetic field can be calculated using the formula B = E/v, where E is the electric field strength and v is the velocity of the proton, resulting in a magnetic field of 0.078 mT directed into the page.
  • Understanding of Lorentz force and its components
  • Familiarity with electromagnetic fields and their interactions
  • Basic knowledge of kinematics and dynamics of charged particles
  • Ability to manipulate equations involving electric and magnetic fields
  • Study the Lorentz force equation F = q(E + v x B)
  • Learn about the properties of uniform electric and magnetic fields
  • Explore the concept of charged particle motion in electromagnetic fields
  • Investigate applications of magnetic fields in particle accelerators
Students in physics, particularly those studying electromagnetism, educators teaching concepts of charged particle dynamics, and researchers working with particle accelerators or electromagnetic field applications.
mwadhwa
A proton, with mass 1.67*10^-27 kg and charge +1.6*10^-19C, is sent with velocity 5.0*10^4 m/s in the x-direction into a region where there is uniform electric field of magnitude 390 V/m in the y direction. What is the magnitude and direction of the uniform magnetic field in the region, if the proton is to pass through undeflected? Assume that the magnetic field has no x-component. Neglect gravitational effects.
I have no idea where to begin! Any help would be greatly appreciated!
can you at least think about which equations you might need in order to answer a question on a moving charge being deflected by an EM field?
You should then imagine a magnetic field does exist, of strength M, in some direction. Think about how the particle will move in this case and it should be obvious how to proceed.
9K
