Finding default unit vectors in 3D modelling
In 3D modeling, when defining elements such as tubes, the local x-axis is aligned with the tube's length. If a unit vector for the z-axis is not specified, modeling software defaults to a coordinate system where the local zx-plane is parallel to the global zx-plane. This creates ambiguity when the local x-axis is perpendicular to the global zx-plane, as the software must employ alternative methods to determine orientation. Understanding this default behavior is crucial for creating accurate transformation matrices.
  • Understanding of 3D coordinate systems
  • Familiarity with transformation matrices
  • Knowledge of unit vectors in 3D space
  • Experience with 3D modeling software
  • Research how to define unit vectors in 3D modeling software
  • Learn about transformation matrices and their applications in 3D graphics
  • Explore the differences between local and global coordinate systems
  • Investigate how various 3D modeling tools handle axis orientation
3D modelers, computer graphics developers, and anyone involved in creating or manipulating 3D objects and transformations.
dr.fea
When you are modelling elements like tubes, the local x-axis is defined along the tubes length.
If a unit vector for the z-axis is not applied, modelling softwares defaults to a coordinate system where the local zx-plane is parallel with the global zx-plane.
I'm not sure what that means exactly, since the zx planes obviously can't be literally parallel if the local and global x-axis isn't pointing in the same direction.
Could someone please explain? My goal is to make a transformation matrix from the default coordinate system to an arbitrary one, but since I don't see how the default one is found, I'm quite stuck..
Sounds like they mean to say the local z-axis is parallel to the global zx plane.
However, when the local x-axis is perpendicular to the global zx plane that rule can't define the orientation. The software must treat that case in some other way.
  • · Replies 16 ·
20K
