Solving Momentum Problems in Ice Skating Collisions
  • Thread starter Thread starter decamij
    Ice Momentum
The discussion revolves around a momentum problem involving two ice skaters colliding and moving together post-collision. The problem requires determining the mass of one skater based on their velocities before and after the collision, utilizing the law of conservation of momentum.
  • Participants discuss using momentum vectors and the conservation of momentum to set up equations. There are questions about the interpretation of angles and the implications of the problem being over-determined.
Some participants have provided guidance on setting up the momentum equations, while others express concerns about the problem's complexity and pedagogical appropriateness. There is an acknowledgment of potential issues with the problem's formulation.
Participants question the clarity of the angle definitions and the implications for the momentum vectors. There is a concern about the problem being over-determined, which may complicate the solution process for students.
decamij
I'm kinda having trouble with this problem. can n e one help me out?
Two ice skaters undergo a collision, after which their arms
are intertwined and they have a common velocity of 0.85 m/s
[27° S of E]. Before the collision, one skater of mass 71 kg
had a velocity of 2.3 m/s [12° N of E], while the other skater
had a velocity of 1.9 m/s [52° S of W]. What is the mass of
the second skater?
I tried to use the law of conservation of momentum and maybe draw a vector diagram, but i only have one momentum that i can actually calculate now. How can i do this (preferably without using components)?
On the contrary, you have THREE momentum vectors! Yes, two of them depend on the unknown mass but surely that won't bother you. Call the unknown mass "m".
"one skater of mass 71 kg had a velocity of 2.3 m/s [12° N of E]"
Okay, that skater's momentum vector is <71*2.3*cos(12),71*2.3*sin(12)> where I am taking the positive x-axis East and the positive y-axis North.
"the other skater had a velocity of 1.9 m/s [52° S of W]". This is the one with mass m so the momentum vector is <m*1.9*cos(52), m*1.9*sin(52)>
After the collision, "they have a common velocity of 0.85 m/s [27° S of E]" and their total mass is 71+m kg so their common momentum vector is <(71+m)*.85*cos(27), (71+m)*.85*sin(27)>.
"Conservation of momentum" means that the sum of the first two must equal the third:
<71*2.3*cos(12)+m*1.9*cos(52),71*2.3*sin(12)+m*1.9*sin(52)>= <(71+m)*.85*cos(27), (71+m)*.85*sin(27)>.
That really gives two equations for the single unknown, m:
71*2.3*cos(12)+m*1.9*cos(52)= (71+m)*.85*cos(27)
71*2.3*sin(12)+m*1.9*sin(52)= (71+m)*.85*sin(27)
so the problem is really "over-determined". You should be able to solve either of these equations for m and then check in the other one. If a value of m satisfies one equation but not the other, this is a BAD problem- it's physically impossible.
"If a value of m satisfies one equation but not the other, this is a BAD problem- it's physically impossible."
I would say that from a pedagogical side, this is a BAD problem, even if it happens to work out.
I do not think it is a good idea to make beginning students work on possibly overdetermined systems.
Sorry, I do not know what [52° S of W] means. Does it mean that the velocity makes the angle of 52° with the negative x-axis in the terms that the positive x-axis points to East and the positive y-axis points to North? If so, than both px and py should be negative, shouldn't they?
Not <(71+m)*.85*cos(27), - (71+m)*.85*sin(27)> instead?
With these changes, the numbers are about all right, but I agree that such a problem is a bad problem for the students.
ehild
Thanx a lot. It's still kinda cloudy, but u cleared it up a lot
  • · Replies 16 ·
