Map complex line to complex circle
The discussion focuses on finding the Linear Fractional Transformation (LFT) that maps the line defined by Re(z) = 1/2 to the circle represented by |w - 4i| = 4. The transformation process involves using the formula T(z) = (z - z1)/(z - z3) * (z2 - z3)/(z2 - z1) and its inverse S(w) = (aw + b)/(cw + d). The solution requires selecting three appropriate points from both the line and the circle to perform the mapping accurately. The key steps include shifting the line to the imaginary axis, mapping it to the interval [0, 2π), and then scaling and shifting to fit the circle's specifications.
  • Understanding of Linear Fractional Transformations (LFT)
  • Familiarity with complex numbers and their geometric interpretations
  • Knowledge of mapping techniques in complex analysis
  • Ability to manipulate complex functions and their inverses
  • Study the properties of Linear Fractional Transformations in detail
  • Learn how to select points for mapping in complex transformations
  • Explore the geometric interpretations of complex mappings
  • Investigate applications of LFTs in various fields such as engineering and physics
Mathematicians, students of complex analysis, and anyone involved in advanced geometry or engineering applications requiring complex transformations.
bmanbs2
Find the Linear Fractional Transformation that maps the line [tex]Re\left(z\right) = \frac{1}{2}[/tex] to the circle [tex]|w-4i| = 4[/tex].
For a transform [tex]L\left(z\right)[/tex],
[tex]T\left(z\right)=\frac{z-z_{1}}{z-z_{3}}\frac{z_{2}-z_{3}}{z_{2}-z_{1}}[/tex]
[tex]S\left(w\right)=\frac{w-w_{1}}{w-w_{3}}\frac{w_{2}-w_{3}}{w_{2}-w_{1}}[/tex]
For [tex]S\left(w\right) = \frac{aw+b}{cw+d}[/tex]
[tex]S^{-1} = \frac{-dw+b}{cz-a}[/tex]
And the final transform is [tex]L\left(z\right) = S^{-1}\left(T\left(z\right)\right)[/tex]
I know how to calculate the transform for any three points to any other three points, so may I just pick any three points on the line and the circle? If not, how do I pick the correct three points?
not the only way to do it but i would break it into the following steps for clarity
- start with the line Re(z) = 1/2, given by z(y) = 1/2+iy
- shift the line to the imaginary axis Re(z)=0
- map the line to the interval [0,2pi), this part is the key step
- map [0,pi) onto the unit circle
- scale and shift the circle to its given centre and radius
  • · Replies 22 ·
