Understanding Negative Exponents in College Algebra
  • Thread starter Thread starter Cod
    Algebra College
The discussion revolves around simplifying algebraic expressions involving negative exponents, specifically in the context of College Algebra. Participants are examining problems that include terms like x^-2 and y^-2, and how to manipulate these expressions correctly.
  • Participants suggest converting negative exponents to positive ones for clarity. There is a focus on the order of operations and the use of parentheses to avoid ambiguity in the expressions. Some participants express confusion regarding the correct interpretation of the problems and the simplification process.
The conversation is ongoing, with various interpretations of the problems being explored. Some participants have offered guidance on how to approach the simplification, while others are questioning the accuracy of the calculations and the setup of the expressions.
There is mention of potential ambiguity in the expressions due to the lack of parentheses, which could lead to different interpretations of the order of operations. Participants are also navigating the challenges of formatting mathematical expressions correctly in the forum.
Cod
I recently started college and I'm in the first Math class, College Algebra. I'm having some problems with simplifying some basic functions if anyone can help me out.
Problems like:
Example 1: x^-2 - y^-2 / x^-1 + y^-1
Example 2: x^-1 + y^-1 / (x+y)^-1
If you noticed, I seem to be having problems with the problems involving negative squares. Any help on how to work these problems is greatly appreciated.
Start by turning those negative rascals positive. That is, X^-1 becomes 1/X, etc. After you've done that take another look at your problem (it will be less confusing then) and decide on your next course of action.
So the correct answer would be:
2y - 2x / y + x ??
I'm a bit confused by your order of operation, in example 1 do you mean:
(x-2 - y-2)/(x-1 + y-1) ?
That is correct. Sorry I couldn't make it look better. I'm not familiar with the coding for making squares and such.
First rule: If there is any chance of ambiguity, use parentheses!
The formula you give first: x^-2 - y^-2 / x^-1 + y^-1
could be interpreted as x-2- (y-2/x-1)+ y-1 or as (x-2-y-2)/(x-1+ y-1).
The first of the two would be technically correct but I suspect you mean the second.
To simplify (x-2-y-2)/(x-1+ y-1), multiply both numerator and denominator by x2y2 (this is essentially the same as multiplying several fractions by the least common denominator).
You get (y2- x2)/(xy2-x2y). Now factor and simplify.
2y - 2x / y + x ??
Not according to my calculations.
Cod,
Could you show what the problem looked like immediately after making the exponents positive?
[edit]
Cod,
Scratch that. Better do it as HallsofIvy's showed (if you can figure out where the X2Y2 comes from, that is).
[edit]
HallsofIvy,
Did you type in a '-' where a '+' was supposed to go?
Thanks, Boulderhead, I did slip an extra negative into that.
It should be (y2- x2)/(xy2+x2y).
I must have rocks in my head!
You're welcome.
Originally posted by HallsofIvy
… I must have rocks in my head!
Why, that's nothing at all. I’m running a regular sand and gravel business over on my end!
  • · Replies 25 ·
