What Is the Work Done by Gravity on a Falling Raindrop?
The discussion revolves around calculating the work done by gravitational force and air resistance on a falling raindrop, modeled as a particle. The raindrop has a mass of 3.34 x 10^-5 kg and falls 50 m at a constant speed, influenced by gravity and air resistance.
  • Participants discuss the formula for work done by gravity and question the sign of the result. There are attempts to apply the work formula and clarify the angle between force and displacement. Some participants express confusion over their calculations and seek explanations for their results.
Participants are actively exploring the definitions and calculations related to work done by gravitational force and air resistance. There is a mix of interpretations regarding the sign of the work done, and some guidance has been provided on the application of the work formula.
Some participants are struggling with the calculations and the conceptual understanding of work in the context of forces acting on the raindrop. There is an ongoing discussion about the implications of constant speed and the role of air resistance.
ramin86
A raindrop of mass 3.34 x 10^-5 kg falls vertically at constant speed under the influence of gravity and air resistance. Model the drop as a particle.
(a) As it falls 50 m, what is the work done on the raindrop by the graviatational force?
J
(b) What is the work done on the raindrop by air resistance?
J
For (a), I tried -mg delta y, to get -3.34x10^-5(9.8)(50), but the answer turned out to be wrong. Please help
Why is it negative? Just recall, what is work?
ehild
Well I found the formula somewhere, and plus it was going downward, but I guess it doesn't work out since the answer was wrong.
Work is force times magnitude of displacement times the cosine of the angle between them. Gravity points downward, the raindrop falls downward, so they make zero angle. The work done by the gravitational force is positive. If you give a negative number as result it will be wrong.
ehild
Well I just multipled 3.34*10^-5(9.8)cos(0) to get 3.27e-4
Is this how I do the problem?
Well I got A wrong, can anyone give me an explanation on how to do it?
And how do I do B?
Well let's start from scratch
Work Definition
[tex]W = \vec{F} \cdot \vec{r}[/tex]
Dot Product:
[tex]\vec{A} \cdot \vec{B} = |\vec{A}||\vec{B}|cos<br /> \theta[/tex]
where [itex]\theta[/itex] is the angle between them
[tex]\vec{A} \cdot \vec{B} = A_{x}B_{x} + A_{y}B_{y} +A_{z}B_{z}[/tex]
Applying the definition to our problem we have
[tex]W_{gravity} = m \vec{g} \cdot \vec{r}[/tex]
[tex]W_{gravity} = m |\vec{g}||\vec{r}|cos0^o[/tex]
or
[tex]W_{gravity} = m(-g_{y})(-r_{y})[/tex]
Answer for both cases is [itex]W = 0.016 J[/itex]
Now Air Resistance Work
Applying again the definition to our problem we have
[tex]W_{air} = \vec{R} \cdot \vec{r}[/tex]
[tex]W_{air} = |\vec{R}||\vec{r}|cos180^o[/tex]
or
[tex]W_{air} = m(R_{y}})(-r_{y})[/tex]
Do you know what [itex]R = ?[/itex]
