Complex Analytic Bijection: Is it a Local Diffeo?
The discussion revolves around whether a complex-analytic bijection \( f(z) \) defined on a region \( R \) implies that its inverse \( f^{-1} \) is also analytic, effectively questioning if \( f: R \rightarrow f(R) \) is a diffeomorphism. Participants explore connections to the inverse function theorem and the implications of differentiability in the context of complex analysis.
  • Some participants propose that the inverse function theorem applies to complex-analytic bijections, suggesting that if \( f \) is analytic and injective with \( f' \neq 0 \), then \( f^{-1} \) is also analytic.
  • Others argue that the terminology of "diffeomorphic" is not standard in complex analysis, preferring terms like "conformal" or "biholomorphic".
  • A participant questions the application of the implicit function theorem, seeking clarification on the conditions under which \( f^{-1} \) is defined and the implications of the Jacobian determinant being non-zero.
  • Another participant discusses the structure of holomorphic functions and suggests that the form of \( f \) can be restricted, hinting at the complexity of diffeomorphisms in this context.
  • Concerns are raised about the differentiability of \( f^{-1} \) and the relationship between the Jacobian matrix and the existence of an inverse, with some participants referencing the determinant of the Jacobian and its implications for invertibility.
  • One participant presents a contradiction argument to show that if \( f' = 0 \), then \( f \) cannot be one-to-one, reinforcing the necessity of \( f' \neq 0 \) for the bijection to hold.
Participants express differing views on the application of the inverse function theorem and the terminology used in complex analysis. There is no clear consensus on whether the conditions discussed lead to a definitive conclusion regarding the analyticity of \( f^{-1} \).
Limitations include the potential ambiguity in the definitions of terms like "diffeomorphic" in the context of complex analysis, as well as the reliance on specific conditions such as the non-vanishing of the derivative \( f' \) and the implications of the Jacobian determinant.
Bacle
Hi, Everyone:
Say f(z) defined on a region R , is a complex-analytic bijection. Does it follow
that f:R--->f(R) is a diffeomorphism, i.e., is f<sup>-1</sup> also analytic?
I know this is not true for the real-analytic case, e.g., f(x)=x<sup>3</sup> , but complex-
analytic is stronger than real-analytic ; I think this may be some corollary of
the inverse function theorem.
Any Ideas?
Yes, you are correct. First, I need to tell you that the word diffeomorphic is not standard in complex analysis. More often, they talk about conformal or biholomorphic functions.
It is indeed true that any analytic bijection is conformal. Here's a nice proof:
Take f an analytic bijection. By the open mapping theorem, it follows immediately that f-1 is continuous.
By the implicit function theorem (of real analysis), it follows that f-1 is analytic outside the set of all f(z) where f'(z)=0. This is a discrete set (=has no accumulation points). The function f-1 is bounded near the points of this discrete set, so by the Riemann removability condition, it follows that f-1 has an analytic continuation. Thus f-1 is analytic.
Thanks, Micromass:
I am curious about this: does the implicit function theorem guarantee the
definability of f as a function wherever f'(z) not zero? Or, alternatively, that
f<sup>-1</sup> is defined wherever the Jacobian Jf has non-zero determinant?
Otherwise, I am not too clear on how/where the implicit function theorem applies.
Can we just conclude from f(f<sup>-1</sup>(z))=z (since f bijective) , that
f'(f<sup>-1</sup>)(z)*f'<sup>-1</sup>(z)=1 (since f is analytic in R)
The implicit function theorem I'm referring to is:
Let [tex]f:D\rightarrow\mathbb{C}[/tex] be analytic with D open. Assume f is injective and f' does not vanish on D. Then
  • The range f(D) is open,
  • The inverse function [tex]f^{-1}:f(D)\rightarrow \mathbb{C}[/tex] is analytic,
  • The derivative is [tex](f^{-1})^\prime(f(z))=\frac{1}{f^\prime(z)}[/tex]
The book where I'm getting this from is complex analysis by Freitag and Busam. I actually think that they should have called this the inverse function theorem instead of the implicit function theorem...
Bacle said:
Hi, Everyone:
Any Ideas?
One way to answer this question is to prove that one can always choose coordinates around any point so that the holomorphic function(non-constant) has the form z^m, for some positive integer, m. While this requires using Taylor series, it reveals the structure of the function. Generally,diffeomorphisms can have many forms. But if the function it is analytic its form is restricted.
Your right, lavinia:
If f'(z)=0 , then we can find an expression f(z)-f(zo)= z<sup>k</sup>g(z) k>1
and an open set U where g(z) is non-zero. Then z<sup>n</sup> is not 1-1.
I was having some technical difficulties about showing the differentiability of
f<sub>-1</sub> , but I think using the inverse of the Jacobian Jf evaluated at
some point ( using the fact that Det(Jf)=|f'(z)|^2 , which is only zero for f'(z)=0),
follows that Jf is invertible and (Jf)^-1 gives us the differentiable inverse of f,
but I am looking into the technical details-- I have a thing for detail-and-example-oriented
classical, get-dirty-with -chalk Mathematics (sorry for the rant ).
Anyway, I'll try to clean up above argument and then post it.
P.S: Sorry, the Tex is not compiling; don't know what I could be doing wrong.
Sorry to bother you all , but I think this too will work:
If f is analytic and 1-1 on a region R, we can show that f'(z)=/0 on R (e.g., assume f'(z)=0 by contradiction, then f has a local rep f(z)=z^k.g(z) for g(z) non-zero, and z^k is k-to-1, and it follows that f is k-to-1).
Then the Jacobian matrixJ(f) is anti-symmetric, with non-zero determinant (since f'(z)=/0, and DetJ(f)=u_x^2+ u_y^2 is non-zero, so J(f) is invertible, and it is easy to show that its inverse has the "right form" , i.e., it is also antisymmetric, which shows that
f^-1 satisfies Cauchy-Riemann.
BTW: Def of antisymmetric : my dad's sister; her name is symmetric.
  • · Replies 108 ·
13K
