Bend Angle After Bending a Bar Around a Pin
The discussion focuses on calculating the bend angle of a bar that wraps around a pin, specifically when the bend angle exceeds 90 degrees. The user has provided the pin diameter, bar diameter, and out-to-out dimensions of the leg traversing the pin but is struggling to derive the bend angle due to the bar's thickness. They are considering using a combination of slope-intercept and circle equations but feel they lack sufficient information to solve for Angle E accurately.
  • Understanding of geometry, particularly angles and tangents
  • Familiarity with slope-intercept form of linear equations
  • Basic knowledge of circle equations
  • Experience with trigonometric principles related to acute angles
  • Research methods for calculating angles in geometric figures involving tangents
  • Learn about the relationship between circle geometry and linear equations
  • Explore techniques for approximating angles in complex shapes
  • Study the properties of acute angles in relation to bar and pin configurations
Mechanical engineers, designers working with bending processes, and students studying geometry and trigonometry will benefit from this discussion.
CaylusCrusade
I think this is the right place to put this. If not I apologize. Feel free to move.
I am trying to solve the bend angle for a bar given specific dimensions. The bend angle is acute as in the bar traverses the pin for more than 90-degrees. The bend angle is the angle of the projected lines from the 2 tangents of the pin.
I'm given the diameter of the pin, and the diameter of the bar. I am also given the out-to-out dimensions of the leg that traverses the pin.
Because the bar has thickness calculating this angle does not give us the bend angle. We are calculating the height to the top corner of the bar and the length to the outside corner of the bar.
From what I have how do I get the bend angle? The accompanying link has a picture. I'm trying to find Angle E given the green line, yellow pin and bar diameter.
http://img696.imageshack.us/img696/697/acuteanglebend.th.png
Uploaded with ImageShack.us
I'm not sure if I can solve with the information given but think I should be able to.
I thought maybe I could solve using some sort of combination of slope-intercept and circle equation but I think I don't have enough information.
I know how have 2 lines with the same slope. I know the y-coordinate of the given hypotenuse matches the y-coordinate of the top outside bar and the x-coordinate of the given hypotenuse matches the x-coordinate of the lower inside bar.
I know I could solve it if the end point of the hypotenuse match either corner (point) of the bar. I know there are plenty of right angles to be made but none that share a side with one I already know.
This may be a bit confusing and I apologize. If you need more clarification please let me know. Thank you for your help.
Can it be done with approximation? Take a guess at the angle then work back from there? It looks like maybe but then you are guessing a point and another point before you get it. Just a thought.
13K
21K
13K
  • · Replies 20 ·
