New Reply
force and tension
Share Thread Thread Tools
Apr28-11, 01:57 AM   #1
force and tension
1. is it true that we have to apply lesser force in lifting a book by holding it near the center than by holding it at the end?
2. why isnt it easier to lift a weight attached to a string when the string is longer than when the string is shorter. is there a theoretical explanation?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Apr28-11, 02:16 AM   #2
Quote by batballbat View Post
1) I am going to go ahead and rephrase this. "Is it true that it takes less work in lifting a book by holding it near the center than by holding it at the end?"
The answer is no. The amount of work done is equal to the change in gravitational energy. You can use any force you want; the amount of force (so long as it's greater than gravity) will only serve to accelerate the book faster or slower.
However, if you grab the edge and try to hold it straight, it may feel like you are doing work as you will be using the smaller muscles of your hand to balance it, and those muscles tend to exhaust more quickly under heavy load.
2) Why would it be easier to lift a weight attached with a longer string? If anything, it should be more difficult: you have to lift more string as well as the weight.
Apr29-11, 08:41 AM   #3
Mentor
That depends on what you mean. The net force that you have to exert to lift an object (without acceleration) is always equal to the weight of the object regardless of where you hold it. But the actual forces exerted by parts of your hand may well vary with how you hold it.
To illustrate how the forces can vary, imagine holding a long wooden stick. Hold it in the middle. Your hand exerts some force on it. Now hold it by the very end. In order to hold it, your hand must exert a torque on the stick to keep it from twisting out of your grip. You'll end up pushing up with one part of your hand and down with another. Parts of your hand will be exerting forces greater than the weight of the stick. (That's why it's hard to hold it by the very end.) But the net force you must exert is still just equal to the weight of the stick.
New Reply
Thread Tools
Similar Threads for: force and tension
Thread Forum Replies
average force and force/tension used General Physics 2
Applied Force Vs. tension Force Introductory Physics Homework 1
Tension Force Introductory Physics Homework 10
Force and tension Introductory Physics Homework 21
force and tension Introductory Physics Homework 1
