New Reply
Differential Pressure Transmitter (DPT) Calibration
Share Thread Thread Tools
Apr28-11, 04:04 PM   #1
I understand the basic principle behind pressure sensor calibration but i am still not able to do a calibration problem. Could someone Explain how you would go about calibrating a standard 4-20mA Differential Pressure Transmitter (DPT) to measure differential pressure in the range 5 to 20 psi?
Or direct me to literature that may be helpful in solving this problem. Thanks in Advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr28-11, 07:16 PM   #2
A calibrated pressure pump is often used. With the calibrated pressure pump, you would "teach" the instrument that 5 psid is 4 mA and 20 psid is 20 mA.
Apr28-11, 08:07 PM   #3
thanks for replying...
Jul10-12, 02:07 AM   #4
if you are using a smart transmitter you can use a hart communicator ..set URV and LRV according to your requirement..
pls refer the following link for more information..
DP transmitter calibration procedure
New Reply
Thread Tools
Similar Threads for: Differential Pressure Transmitter (DPT) Calibration
Thread Forum Replies
Pressure gauge calibration General Physics 3
Differential Pressure measurement problem General Engineering 1
bernoulli-pressure differential airfoil Mechanical Engineering 4
Is high pressure differential always a bad thing? Mechanical Engineering 9
pressure differential Introductory Physics Homework 1
