Thread Closed
Is there plasma that doesn't radiate visible light? I think the
Share Thread
Apr29-11, 08:34 AM   #1
Is there plasma that doesn't radiate visible light? I think the electrons falling back to the nucleus radiate visible photons. But what if the plasma only has particles that are not atoms?
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Apr29-11, 10:11 AM   #2
Particles that are "not atoms"? Could you give us an example of what you have in mind?
May2-11, 04:50 PM   #3
Recognitions:
Gold Membership Gold Member
Quote by rsr_life View Post
I think he means that the particles in a plasma aren't bound into atoms, so do they radiate light. I believe they will emit various wavelengths of light due to accelerations of electrically charged particles. But i'm not sure.
May5-11, 08:52 PM   #4
Yes.. particles in plasma that aren't bound to atoms... what if they are not charged.. then they won't radiate? Or do all plasma contain charged particles?
May5-11, 09:28 PM   #5
Recognitions:
Quote by Varon View Post
You will not have a plasma on earth that isn't made up of charged particles. The only place that could would be inside massive objects such as stars. And even then not really, as a free neutron has a half life of 15 minutes.
May8-11, 06:35 PM   #6
What are examples of plasmas that only contain electrons? Since there is no nucleus to make it fall to lower state, then no photons would be radiated, right? Then this plasma is totally invisible to visible spectrum?
May8-11, 07:22 PM   #7
Mentor
Er... an atomic transition is NOT the only way to create light. A charge particle being accelerated is another example. What do you think synchrotron light sources are? Or what about free electron lasers? You pass bunches of electrons through something that causes it to wiggle up and down, and viola! You get light!
Zz.
May8-11, 08:12 PM   #8
i see. what plasma sources have both nucleus and electrons in the plasma and what plasma sources have pure ions only? Any site with a list of them?
May9-11, 05:22 AM   #9
Mentor
Your fluorescent lamps.
The ion beam at RHIC, ion beam milling equipment, etc.. etc.
Zz.
May9-11, 07:59 AM   #10
Recognitions:
Quote by ZapperZ View Post
Zz.
I thought that a plasma was defined as having net neutral charge.
May9-11, 09:05 AM   #11
Mentor
Quote by sophiecentaur View Post
I don't think that's a necessary criteria, is it?
If it is, then asking for "ion beam plasma" would be an oxymoron, which probably won't surprise me.
Zz.
May9-11, 11:06 AM   #12
Recognitions:
Does solar wind radiate visible light? How about a household air ionizer?
Respectfully,
Steve
May9-11, 01:33 PM   #13
Recognitions:
Zz.
I wouldn't normally just quote Wikkers but they, and a few other more raggedy sites, seem to reckon that a plasma is overall neutrally charged.
It wouldn't be the first oxymoron I'd come across!
May9-11, 06:17 PM   #14
Wiki entry on Plasma stated:
"Definition of a plasma
Plasma is loosely described as an electrically neutral medium of positive and negative particles (i.e. the overall charge of a plasma is roughly zero)."
Is this true?
So overall charge is roughly zero for plasma composed of atoms? And for those composed only of ions.. it's negative charge? Is this correct? So how do each of them (neutral and charged) behave? What is the major (dramatic) difference between them aside from charge?
May10-11, 12:46 AM   #15
Recognitions:
How can you conclude that a plasma can consist of only Ions if you are quoting an article saying a plasma is neutral?
May10-11, 01:32 AM   #16
Zapper mentions about ion plasma beam.. which I assumed is negative charged since it is composed of electrons
May10-11, 01:55 AM   #17
Recognitions:
You are assuming Zapper is correct?
Thread Closed
Similar discussions for: Is there plasma that doesn't radiate visible light? I think the
Thread Forum Replies
What is plasma? Biology, Chemistry & Other Homework 6
Plasma MHD Advanced Physics Homework 0
Plasma or LCD TV? Computers 11
About plasma General Physics 6
