Statistical mechanics - diatomic particles leaving and entering a box
The discussion focuses on calculating the time required for the pressure in a box containing air to drop from 3*10^5 N/m² to 1.2*10^5 N/m² through a small hole. The relevant equation derived is (dP/dt)=[16π³ak²T²NPx]/[V²Im], where V is the volume, T is the temperature, and N is the number of particles. The user seeks clarification on the variables m and I, and whether an integral is necessary to solve for time.
  • Understanding of the ideal gas law (PV = NkT)
  • Familiarity with differential equations in physics
  • Knowledge of statistical mechanics concepts related to particle dynamics
  • Basic calculus, particularly integration techniques
  • Research the derivation of the equation for (dN/dt) in statistical mechanics
  • Learn about the implications of the ideal gas law in dynamic systems
  • Study integration techniques for solving differential equations
  • Explore the effects of pressure differentials on gas flow through orifices
Students and professionals in physics, particularly those studying thermodynamics and statistical mechanics, as well as anyone involved in fluid dynamics and gas behavior analysis.
khfrekek92
A box of volume .5m^3 contains air pressure 3*10^5 n/m^2, and air composition of 80% N2 and 20% O2. There is a small hole of area 1*10^6 m^2 in one face. The exterior of the box has air of the same composition and temperature but pressure of 1*10^5. How long will it take for the pressure in the box to drop to 1.2*10^5 n/m^2?
(dP/dt)=[16[pi]^3ak^2T^2NPx]/[V^2Im]
After Using PV=NkT to getVdP +PdV=kTdN+Nkdt (then since pressure and temperature are constant) dP/dt=(kT/V)dN/dt
dNdt was a 10-dimensional integral which took quite awhile to solve for, and nw I am left with:
Now I need to solve for how long it will take to go from a pressure of 3*10^5 to 1.2*10^5. How do I do that using this above equation? What do I use for m or I? Do I need to take the integral? Thanks so much in advance!
You're going to need to give more information on how you got your dN/dt function?
  • · Replies 36 ·
