How Does Halving Friction Affect the Speed of a Brick Sliding Down a Plank?
  • Thread starter Thread starter meh6287
    Energy
The discussion focuses on calculating the new speed of a brick sliding down a plank after halving the coefficient of friction. Initially, the brick reaches a speed of 2.5 m/s at the bottom of a 2.0m long plank inclined at 30 degrees. The frictional force must be calculated using the correct formula, which involves the sine of the angle of incline. After correcting the calculations, the frictional force for the second scenario remains 2.5 N, leading to a new speed that is greater than 2.5 m/s.
  • Understanding of Newton's laws of motion
  • Knowledge of frictional force calculations
  • Familiarity with trigonometric functions, specifically sine
  • Basic principles of energy conservation in physics
  • Review the concept of frictional force in inclined planes
  • Learn about energy conservation and its application in physics problems
  • Study the effects of varying coefficients of friction on motion
  • Practice solving problems involving inclined planes and friction
Students studying physics, particularly those focusing on mechanics and motion, as well as educators looking for examples of friction and inclined planes in action.
meh6287
A brick slides down a wooden plank 2.0m long tilted so that one end is at a height of 1.0 m. The brick's speed at the bottom is 2.5 m/s. The plank is then sanded smooth and waxed so that the coefficient of friction is half what it was before and the brick is slid down again. What is the new speed of the brick at the bottom?
so far all i could come up with is that theta=30degrees
then i did f x m x g x cos30) x d = .5 x m x v^2 for the first block
and then w=(.5f x m x g cos30) x d = .5 x m x v^2 for the second block
then i canceled the m's, and i pluggedin v for the first equation and solved for f, and then i tried to put that f value in and come up with an answer for v but that answer is wrong because it comes out to less than 2.5 which doesn't make sense.
Thank you for the help in advanced.
what about the work done by gravity?
First of all, great job on setting up the equations correctly! It looks like you have a good understanding of the concepts involved in this problem. However, there may be a small error in your calculations.
When you plugged in the values for the first equation, you wrote "f x m x g x cos30) x d". However, the formula for frictional force is actually "f x m x g x sinθ", where θ is the angle of the incline. Since θ is 30 degrees in this problem, the correct term to use would be "sin30". This may be why your final answer is incorrect.
Also, when you solved for f, you should have gotten a value of 2.5 N. This means that the frictional force for the second block should also be 2.5 N, since the coefficient of friction is half of what it was before. Plugging this value into the second equation should give you the correct answer for the new speed of the brick at the bottom.
I hope this helps and good luck with your homework!
  • · Replies 17 ·
