How to Implement an ALU at Gate Level in Verilog?
  • Thread starter Thread starter alt3r
    Alu
The discussion focuses on implementing an Arithmetic Logic Unit (ALU) at the gate level using Verilog. Key components include three registers: an Instruction Control Register (3-4 bits), Register A (8, 16, or 32 bits), and Register B (same size as Register A). The control register dictates the operation performed on the registers, utilizing logical operations such as AND, OR, NOT, ADD, and SUB. Additional considerations include implementing a carry flag and avoiding closed loops by using an auxiliary register, D, for intermediate calculations.
  • Understanding of Verilog syntax and structure
  • Knowledge of digital logic design principles
  • Familiarity with binary arithmetic operations
  • Experience with register and flip-flop configurations
  • Study Verilog coding techniques for implementing combinational logic
  • Learn about the design and implementation of microprocessors
  • Explore the use of carry flags in ALU design
  • Investigate advanced HDL techniques to avoid closed loops in register operations
Electronics engineers, computer architecture students, and anyone interested in digital circuit design and Verilog programming will benefit from this discussion.
alt3r
Hello guys,
i want ALU implemented in gate level in verilog, please help me
That's a pretty standard simple exercise.
Just set up three registers (or bit-level flip-flops) for the number of bits that you wish to deal with.
1. Instruction control register - Usually just 3 or 4 bits wide
2. Register A (for accumulator) - Might be 8, 16, 32, or whatever you want
3. Register B - Must be the same size as register A
Then just write the code based on the contents of the control register.
In other words, if the control register contains say 000 then have Register B AND with register A leaving the result in A.
If the control register contains say 001 then have register B OR with register A leaving the resultes in A.
You can do similar things with various binary codes in your control register.
It's a pretty simple routine. Once you have the three registers defined, the rest is just IF THEN statements of the form:
IF control=000 THEN A = B LOGIC A
IF control=001 THEN A = B LOGIC A
IF control=010 THEN A = B LOGIC A
IF control=011 THEN A = B LOGIC A
IF control=100 THEN A = B LOGIC A
Where "LOGIC" is something like AND, OR, NOT, ADD, SUB, ect.
And so on. If you need more control make the control register 4-bits wide or wider.
You might also want to implement a carry flag, or other types of flags. Keep going and the next thing you know you'll be designing a microprocessor!
Hope this helps. You'll still have to work out the actual syntax and initial register set up, but if you are taking a course in this that part should be relatively straight-forward.
Here's a link to a similar assignment, it doesn't give the answer but by it might be helpful:
http://www.u-aizu.ac.jp/~yliu/teaching/comparch/lab1.html
By the way, using A as both the accumulator and one of the initial registers can sometimes be a bit tricky with some HDL. If you have problems with that you might try adding yet another register say D and write the code as follows
IF control=000 THEN D = B LOGIC A
IF control=001 THEN D = B LOGIC A
IF control=010 THEN D = B LOGIC A
IF control=011 THEN D = B LOGIC A
IF control=100 THEN D = B LOGIC A
This way you will be guaranteed good results without the possibiliy of causing a closed loop. It's actually been a while since I've done any HDL so maybe others will respond with some better ideas.
