Register to reply
How to divide sin?
by Nano-Passion
Tags: divide
Share this thread:
Nano-Passion
#1
May2-11, 04:06 PM
P: 1,306
Its a word problem but I will just state everything here in simple form.
Given
V initial = 100ft/s
r=300ft
r= 1/32 V^2 Sin 2theta
Unknown
Solve for theta
3. The attempt at a solution
300=1/32 (100)^2 sin 2theta
300= 1/32 (10000) sin 2theta
300= 312.5 sin 2theta
300/312.5= sin 2theta
.96 = sin 2theta
I know the next step would be to divide by sin but how???
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
Mark44
#2
May2-11, 04:20 PM
Mentor
P: 21,307
Quote Quote by Nano-Passion View Post
Given
V initial = 100ft/s
r=300ft
Unknown
Solve for theta
.96 = sin 2theta
"sin" is not a number, and is not multiplying 2theta. Sine is a function, so your line at the end is similar to .96 = f(2x).
If you have a variable that is the argument to a function, what can you do to get at the function's argument?
QuarkCharmer
#3
May2-11, 04:21 PM
QuarkCharmer's Avatar
P: 1,035
You have 2θ there. That is really like saying Sin(θ+θ) isn't it?
tiny-tim
#4
May2-11, 04:24 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
How to divide sin?
(have a theta: θ and try using the X2 tag just above the Reply box )
.96 = sin 2theta
nooo the next step is to use sine tables (or the arcsin button on your calculator)
Nano-Passion
#5
May2-11, 04:57 PM
P: 1,306
Quote Quote by Mark44 View Post
hmm..
f(2x)=.96
2x=.96
x=.48??? -.-grrr
I'm having a little trouble =/ I can't seem to get the inverse ..
What I did before was I asked myself:
sin of what? = .96 <-- plugged it in calculator as sin of inverse =/
2θ = 1.287
θ = .6435
But I want to figure our whats going on in between.
Quote Quote by tiny-tim View Post
nooo … the next step is to use sine tables (or the arcsin button on your calculator)
Thanks but I want to really understand the steps in between and not just get the answer through the calculator.
And is there a button here for theta?
Mark44
#6
May2-11, 04:58 PM
Mentor
P: 21,307
hmm..
f(2x)=.96
2x=.96
f is a function. What happened to it? You can't just ignore it.
x=.48??? -.-grrr
rock.freak667
#7
May2-11, 04:59 PM
HW Helper
P: 6,202
If you have sinx = A, then x = sin-1(A).
Nano-Passion
#8
May2-11, 05:07 PM
P: 1,306
I know but I didn't know what to do, can you help me?
I'm used to things such as:
f(x) = 2x+4
y = 2x+4
y/2 -2 = x
f-1x = 1/2y - 2
but when it comes to
f(2x) = .96 then I'm confused on what to do.
AwesomeSN
#9
May2-11, 05:17 PM
P: 15
Isn't sin2[tex]\theta[/tex] a trigonometric Identity that becomes 2 sin [tex]\theta[/tex] cos[tex]\theta[/tex]?
Mark44
#10
May2-11, 05:21 PM
Mentor
P: 21,307
In your problem, the function is the sine function, and your equation is:
sin(2x) = .96
(I'm using x instead of theta.)
The thing to do is to apply the inverse sin function to both sides.
sin-1(sin(2x)) = sin-1(.96)
==> 2x = sin-1(.96)
==> x = (1/2)sin-1(.96)
This will give you one value for x, but it might be that your problem calls for other solutions. If so, you will need to use some of the ideas from trig to get the other solutions.
Mark44
#11
May2-11, 05:23 PM
Mentor
P: 21,307
Quote Quote by AwesomeSN View Post
But in this problem, that's the wrong way to go. Making this replacement turns the problem into [itex]2 sin \theta cos\theta = .96[/itex]
and this doesn't get you closer to a solution. Using inverse functions does.
Nano-Passion
#12
May2-11, 05:44 PM
P: 1,306
sin(2x) = .96
==> 2x = sin-1(.96)
Thanks, but please bare with me, my goal is to understand everything in mathematics as much as I can. I hope I am not being a bother but I am not satisfied with knowing that I should simply multiply by the inverse on both sides.
My question is, how does sin-1 cancel with sin when you multiply them together? It doesn't sound mathematically logical? I need the steps in between.
Mark44
#13
May2-11, 06:04 PM
Mentor
P: 21,307
No, you're not being a bother. If you don't understand something it's better to keep asking questions until things are clear.
One thing that you need to understand here is that the operation is NOT multiplication. This is something you have not been clear on since your first post in this thread.
sin(2x) is sometimes written as sin 2x. In either form it is NOT sin times 2x - it's sin of 2x. Similar to what I wrote earlier - f(2x) is not f times 2x. It's f OF 2x, where f was the name of some unspecified function.
They're not being multiplied. What is happening is that I am forming a composite function. Whenever you have a function that has an inverse, applying them together in either order gives you the identity function, the function that leaves its argument completely unchanged.
For example, if f(x) = 2x + 3, then the inverse of this function is f-1(x) = (x - 3)/2.
f(f-1(2) = 2 and f-1(f(0)) = 0.
You can verify these statements by using the formulas for the functions.
In a similar way sin(sin-1(x) = x, but there are some restrictions of the values of x that are allowed. Also, in the opposite order, sin-1(sin(x)) = x, and there are some restrictions here, as well. In the first equation, x has to be between -1 and +1, inclusive. In the second equation, x has to be between -pi/2 and +pi/2 if you're working in radians, or between -90 deg and +90 deg, if you're working in degrees.
RocketSci5KN
#14
May2-11, 06:06 PM
P: 163
Yes, sin-1(sin(theta) ) = theta
eumyang
#15
May2-11, 06:10 PM
HW Helper
P: 1,347
Quote Quote by RocketSci5KN View Post
That's not always true. Did you not read Mark44's post above?
For instance, what is
[tex]\sin^{-1} (\sin 3\pi/4)[/tex]
? Hint: it's not 3π/4.
Hurkyl
#16
May2-11, 06:17 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,091
Noooooooo! You have to apply methods for solving trigonometric equations! Pretending it's an ordinary invertible operation you can simply "undo" is incorrect!
Hurkyl
#17
May2-11, 06:18 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,091
Do they still teach English students how to diagram sentences? If you've seen that, there's a similar thing for mathematical expressions.
The diagram (which can called a "parse tree") for the expression 2x+1 would be:
  *     1
2   x
Note this reflects how it's computed -- if you substitute x=4 and computed, you would
  • Replace x with 4
  • Compute 2*4 and replace that little part of the tree with the result:
      8     1
  • Compute 8+1, and replace the tree with 9
Functions, such as sin are like + and * and other operations. The diagram for the expression
sin 2x
looks like
 sin
2   x
And for
arcsin sin 2x
it would be
arcsin
 sin
2   x
I hope this helps you understand how to read mathematical expressions.
RocketSci5KN
#18
May2-11, 06:33 PM
P: 163
Oops... forgot about the range of theta this IS true for, as noted by Mark44.
Register to reply
Related Discussions
Do we divide by the wet or the dry ? Materials & Chemical Engineering 2
Divide by zero Special & General Relativity 1
Divide by zero General Discussion 5
Divide by Zero General Physics 11
Divide by zero? General Math 30
