Can I adjust R4 and R5 to maintain a 12k input impedance?
  • Thread starter Thread starter likephysics
    Network Resistor
The discussion revolves around adjusting resistor values R4 and R5 in a resistor network to maintain an input impedance of 12k ohms. Participants explore the implications of current flow in the circuit and the relationship between the resistors involved.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant expresses confusion about the current flow in the resistor network, suggesting that input and return currents should be equal but noting that some current appears to flow to ground.
  • Another participant clarifies that no current actually flows "to ground" in the conventional sense, proposing that the resistors connected to ground should be treated as parallel paths in the circuit.
  • A question is raised about whether the two grounded resistors are in parallel with the 12k resistor, which is confirmed by another participant.
  • A participant mentions that the 12k represents the input impedance of a receiver IC and indicates a need to increase R4 and R5 to maintain this impedance level.
Participants generally agree on the configuration of the resistors and the nature of current flow, but there is ongoing uncertainty regarding the adjustments needed to maintain the desired input impedance.
There may be limitations related to the assumptions about current flow and the specific values of R4 and R5 that have not been fully explored or defined.
likephysics
How do I reduce this resistor network.
The input current and the return current should be equal. But in this case, some current will also flow to ground. Can't get my head around this.
No current flows "to ground" per se. Just connect the two ends of the resistors that have ground symbols with a wire -- that's the only other path for current. No current "leaves" the system the way it's drawn.
So the two grounded resistors are in parallel with the 12k resistor?
Yep!
The 12K is the input impedance of a receiver IC. I got to increase R4,R5 to keep the impedance close to 12k.
  • · Replies 23 ·
