Is Your Wave Packet Momentum Wave Function Correctly Normalized?
The discussion revolves around normalizing a momentum-space wave function for a wave packet, specifically defined as A(p)=C for 0 and , and subsequently determining the standard deviation.
  • Participants discuss the normalization process and the correct form of integrals for expectation values. There is uncertainty regarding the inclusion of Planck's constant in the integrals and the implications of the results obtained for the standard deviation.
Some participants have provided corrections to the integral forms used for normalization and expectation values. There is ongoing clarification about the role of Planck's constant in the calculations, and while some values have been computed, there remains a focus on ensuring the correctness of the approach and understanding the implications of the results.
Participants are navigating potential misunderstandings regarding the definitions and calculations involved in quantum mechanics, particularly in the context of wave functions and their properties. There is mention of textbook guidance that may influence the normalization constant and the interpretation of results.
knawd
A wave packet is described by the momentum-space wave function A(p)=C when 0<p<p0, and A(p)=0 for all other values of p. Here C is a constant.
i) Normalize this wave function by solving for C in terms of p0.
ii) Calculate the expectation values <p> and <p2>. From these compute the standard deviation in terms of p0.
For normalization: h(integral from 0 to p0)A*(p)dp=1, h being Planck's constant.
<p>=h(integral from 0 to p0)pA*(p)dp
<p2>=h(integral from 0 to p0)p2A*(p)dp
(I am not entirely sure if this equation for <p2> is correct, it may be <p2>=h(integral from 0 to p0)p2A*(p)A(p)dp)
standard deviation=<p2> - <p>2
i) When I normalized the wave function from 0 to p0, I got C=1/sqrt(h*p0).
ii) This is the part I'm struggling with. Typically <p> would be equal to zero when integrated from -infinity to +infinity, but this is from 0 to p0. Doing this I am getting <p>=p0.
For <p2> I am integrating from 0 to p0 and getting <p2>=(1/3)p02.
One of these values (or both) can't be correct because when I try to calculate the standard deviation=<p2> - <p>2 = (1/3)p02 - p02= -(2/3)p02. I'm pretty sure standard deviations can't be negative. So the part of the question I really can't figure out is what I'm doing wrong when I try to find the expectation values.
Your integrals are all wrong. For normalization, you want
[tex]\int_0^{p_0} A^*(p)A(p)\,dp = 1[/tex]
Similarly, the expectation values are
[tex]\langle p \rangle = \int_0^{p_0} A^*(p)pA(p)\,dp[/tex]
and
[tex]\langle p^2 \rangle = \int_0^{p_0} A^*(p)p^2A(p)\,dp[/tex]
Okay. So using those integrals I'm getting:
C=1/sqrt(hp0)
<p>=p0/2
<p2>=p02/3
stdev=(1/12)p02
Also, am I right in using h in front of all of the integrals for this problem?
C=1/sqrt(hp0)
<p>=p0/2
<p2>=p02/3
stdev=(1/12)p02
The last quantity is the variance, not the standard deviation.
No. Why do you keep putting it there?
So the standard deviation is sqrt(<p2>-<p>2), which equals p0/sqrt(12)?
My textbook says to put 2*pi*hbar (=h) in front of the integrals, I wasn't sure if that had something to do with me getting strange answers though.
Yup.
It would affect the normalization constant but would cancel out of the other integrals, leaving your answers for the expectation values the same.
Alright. Thank you for clearing things up for me.
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 46 ·
