Understanding capacitance formula
The discussion revolves around the capacitance formula, specifically addressing the meaning of the area of overlap between capacitor plates, the measurement of distance between the plates, the concept of static permittivity in a vacuum, and the time constant in relation to capacitance. The scope includes theoretical and conceptual clarifications.
  • Some participants inquire about the definition of the area of overlap between capacitor plates and whether it refers to the actual area of the plates.
  • There is a suggestion that the distance between the plates is typically measured in meters, aligning with SI units.
  • One participant notes that the relative static permittivity of vacuum is defined as 1, while others discuss the implications of this in terms of charge storage capability.
  • Concerns are raised about the formula's applicability when the dimensions of the plates are not significantly larger than the separation distance, mentioning edge effects.
  • Some participants explore the idea that a vacuum does not prevent charge separation on capacitor plates, questioning the relationship between charge presence and static permittivity.
  • There is a discussion about the time constant being measured in seconds, with references to the units used in capacitance calculations.
  • A later reply asserts that the static permittivity of a vacuum is at a minimum in typical situations, suggesting a nuanced understanding of its role in capacitance.
Participants express differing views on the implications of static permittivity in a vacuum and its role in charge storage, indicating that multiple competing perspectives remain unresolved. There is also some agreement on the measurement units but a lack of consensus on the broader implications of these measurements.
Limitations include assumptions about the dimensions of the plates and the conditions under which the capacitance formula is valid. The discussion also reflects varying interpretations of static permittivity and its implications in different contexts.
Femme_physics
Understanding "capacitance" formula
In this formula
http://img810.imageshack.us/img810/9127/capacitance.jpg 1) What does it mean the area of overlap of the two plates? Does it mean the "area" of the plates? And, is the area of one plate always the same size of the other plate?
And also,
2) The distance between the plates is measured is what, normally? mm?
And they also said that "εr is the relative static permittivity (sometimes called the dielectric constant) of the material between the plates (for a vacuum, εr = 1);"
So my last question:
3) In a vacuum there is no static permittivity or that there is maximum static permittivity? If what I understand static permittivity is pretty much like the ability to store charge...? So, vacuum has no ability to store charge...shouldn't it be zero?
PS and while I'm at it, is the time constant measured only in seconds?
1: the area where you have both plates separated by this distance. Think of a variable capacitor, where this overlap area varies.
http://en.wikipedia.org/wiki/Variable_capacitor
or imagine you have a piece of foil, covered by piece of plastic wrapper, covered by another piece of foil. The area where foil overlaps.
The formula is approximate and ignores capacitance between parts that do not overlap.
2: same unit in which you measure the electric constant. That is, meters.
3: relative static permittivity of vacuum is 1 . 'Relative static permittivity' of anything else is relative to the vacuum.
edit: time constant, same units that you use for other quantities (or else you have to convert). Farad is s4A2kg-1m-2 so that'd be seconds. In general, SI uses seconds, kilograms, meters, etc.
If you state everything in SI units then you should have no trouble with getting the answer right. It's just a matter of remembering to! :smile:
The formula you are quoting only works for an arrangement where the dimensions of the plates is a lot more than the separation. 'Edge effects' come into it when you have small plates and large separation.
For a small plate over a large plate, the area would be that of the small plate; i.e. the bit of the small plate that overlaps the large plate.
Re "vacuum". Why should the fact that there is no charge 'in' a vacuum stop extra electrons appearing on one plate and a scarcity of electrons on the other plate? That's what happens when a capacitor is charged. For a capacitor with a dielectric, there is polarisation of the molecules (but no flow) within the intervening insulator which allows a greater charge displacement for the same PD.
Ahh...there's the punchline :)
Hmm. I'll indulge in this fact later and repost here.
So a vacuum is not a maximum or a miminum, right? It's just a relative point?
The static permittivity is at minimum for a vacuum, at least for typical situations.
  • · Replies 17 ·
  • · Replies 16 ·
