Hard Disk - Motherboard Compatibility
  • Thread starter Thread starter rahulkhajuria
    Disk Hard
The discussion centers on the compatibility of hard disks between two PCs with different motherboards. P.C.1 features a MicroStar 865G/GVM3-V motherboard with an 80 GB WD hard disk (1.5 Gb/s), while P.C.2 has an ASUS M2N68-AM SE2 motherboard with a 250 GB Seagate BARRACUDA (3 Gb/s). Both hard disks are SATA, ensuring compatibility without the need for adapters. However, caution is advised regarding P.C.1's 250 Watt power supply, which may be insufficient for stable operation when swapping components.
  • Understanding of SATA hard disk specifications (1.5 Gb/s and 3 Gb/s)
  • Knowledge of power supply requirements for PC components
  • Familiarity with motherboard specifications and compatibility
  • Basic troubleshooting skills for PC hardware
  • Research power supply requirements for different PC configurations
  • Learn about SATA interface standards and compatibility
  • Investigate safe practices for swapping PC components
  • Explore motherboard manuals for detailed compatibility information
PC builders, hardware enthusiasts, and anyone looking to upgrade or swap hard disks between systems safely.
rahulkhajuria
I have 2 P.C.s as follows
P.C.1 : 865G/GVM3-V (MS -7101 V2.0) M-ATX MicroStar Motherboard
Pentium 4 Dual Core Processor
80 GB WD Hard Disk 1.5 Gb/s
512 MB DDR1 RAM
250 Watt Power Supply
Bought in 2006
P.C.2 : M2N68-AM SE2 ASUS Motherboard
ATHALON Processor
250 GB Seagate BARRACUDA 7200.10 Hard Disk 3 Gb/s
2 GB DDR2 RAM
400 Watt Power Supply
Bought in 2009
The Hard Disk on P.C.1 has the following thing written on it - 5v ... .48A
12v ... .50A
The Hard Disk on P.C.2 has the following thing written on it - 5v ... .72A
12v ... .52A
Now , I want to install the Hard Disk on P.C. 1 on P.C. 2 & Vice Versa .
However , I am concerned that when I try this out what if there is some spark or short-circuit due to some sort of power-mismatch because of which I end up killing one of the motherboards or HardDisks . Can I safely just swap the 2 Hard Disks ? Is there any more information I need to give regarding these P.Cs ?
What are the precautions in general that one needs to bear in mind before adding new devices onto a P.C. Or in other words , how does one check whether a certain device will be compatible with a certain system or not ?
Computer science news on Phys.org
I have never heard of hard drive, motherboard incompatibility. I wouldn't worry about it, especially since both of those drives are SATA so you don't even need an adapter! Only difference is one is 1.5gb/s sata and one is 3gb/s sata, and I am pretty sure you can just use a 1.5gb/s cord on a 3gb/s, read the manuals for them just in case though.
Hard drive swaps should not be an issue. You may have power supply issues with pc 1. 250 watts is marginal. I would be uncomfortable with less than 300 watts with that setup.
  • · Replies 62 ·
  • · Replies 23 ·
